starter relay
Old December 2nd, 2006, 07:48 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
starter relay
if the starter relay on the fenderwall is bad will that make the car not start as if the battery doesnt have enough juice
85 svo. work in progress
Old December 2nd, 2006, 08:08 PM   #2
TENGRAM is on a distinguished road
it wouldn't crank at all if the relay was out. sounds like your battery is drained.
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 08:15 PM   #3
its brand new. i just put it in along with a 130a 3g alternator it started right up after ,run for 15-20 min turned off wouldnt start again cranked but lights went dim and wouldnt start
Old December 2nd, 2006, 08:50 PM   #4
glad to hear you got that alt put in...unfortunately reads like that might be the issue...are you positive you installed it correctly? might want to go back over everything to make sure. good luck and let us know
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 08:52 PM   #5
i had this prob b4 the batt and alternator thats why i replaced them.
Old December 2nd, 2006, 09:00 PM   #6
check all of your grounds... to engine block, to starter, and the one going from block to firewall. make sure they're good/clean connections to bare metal. also, it's a good idea to add a ground, from the block or cylinder head to the swaybar mount.
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 09:07 PM   #7
check THIS THREAD
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 09:10 PM   #8
ugh..
Old December 2nd, 2006, 09:11 PM   #9
im mad at my car
Old December 2nd, 2006, 09:16 PM   #10
i hear ya, BTDT. just take a break and resume when you're ready. in the meantime read up on possible solutions. believe me when you solve the problem you'll feel great. good luck
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 09:27 PM   #11
im done for the night, is too cold out and the daylight savings nonsense. i spend my paycheck on the battery and alternator and my car still sits in my backyard.
the story goes like this. head gasket blew so i changed them car was good couple days later battery craps out on me. bought a walmart cheap, lasted for 3weeks or so. then the other night i was showin the gf how to drive stick. she did good 1st the then coming to a stop the car was jerking and such then stalled. then it wouldnt crank. opened hood tapped starter relay,then is started crankin but then the lights went dim as if there was no juice. so i bought a new bosch batt. and 130a alternator and popped that junk in 2day after work. then started it up and it was good. ran if for 20 min turned if off and then when to start it but it wouldnt go. it cranked but the lights went dim and it wouldnt start.
Old December 2nd, 2006, 09:53 PM   #12
like i said, Been There Done That... i've had to have my GF push start my car before. my 85 was a wiring nightmare. read that article i posted before, but the important bits are as follows: verify good ground connections, add an extra ground, and use fine-stranded battery cables.
BTW, if your GF doesn't F with you too much about your car not starting, keep her around. good girls are hard to find. my2cents
89 GT t5 3.73
www.my5oh.com/
Old December 2nd, 2006, 10:05 PM   #13
she thinks she broke it
Old December 2nd, 2006, 10:16 PM   #14
it starts good wen ya push it lol
Old December 2nd, 2006, 10:37 PM   #15
its gutta be a ground. i went outside took the neutal off the batt. fiddled with the starter relay, put the battery cable back on and it started up wicked good
Old December 2nd, 2006, 11:29 PM   #16
i drove around it was good came home turned it off then went to start it and ............gayness so ima check all the grounds
Old December 3rd, 2006, 01:07 AM   #17
cool, let us know
89 GT t5 3.73
www.my5oh.com/
Old December 3rd, 2006, 10:05 PM   #18
i put a new battery terminal on the neg. and i breathed on the key and it started right up. on off on off on off. good. drove around the block the tempp guage went up pretty high then a min later dropped to normal. went home, it wouldnt start, so i went in my house to get a drink and came out my door and there was a puddle under my car. i push it back and ................oilllllllllllllllllllllllllll wtf.
Old December 3rd, 2006, 10:40 PM   #19
geez, when it rains it pours. hopefully its something simple like a drain pan plug came loose...check it out in the morning and let us know. as for the fact that it wouldn't start up again after fully warmed up, its really starting to sound like a ground problem...not that that means much with your engines "blood" on the ground, but like i said hopefully its something simple.
89 GT t5 3.73
www.my5oh.com/
Old December 3rd, 2006, 10:46 PM   #20
i regret buying the car. but 2000$ will turn that around. ima sell my soul for a new motor
Threads Similar to: starter relay
Relay akatagyourit 2.3 Mustangs 2 July 21st, 2007 12:39 PM
fuel relay Mustang RacR94 V6 Mustangs 3 April 15th, 2007 05:24 PM
PCM Relay and/or Ideas David C 5.0 Mustangs 6 December 3rd, 2006 11:22 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
WOT A/C Cutoff Relay Cmauney 5.0 Mustangs 3 February 25th, 2006 10:42 AM
