coil overs!?
whats up guys got a 89 gt. want to get coil overs for it... right now i have 90/10 and everything else is stock. want to save some wieght up front and make the car hook alil better.. what size spring and rate should i get.. was thiking a 14" 200lb. my car wieghs 3300 with me in it... any input is appreciated... thank you..
14" 150lb spring would work a bit better.
yea one of my buddys has a 14" 150lb and his car wieghs 3100 with him in and hes gettin coil bind...the car just blows the tire away and gets shitty 60ft. thts why i was thiking going with a heavier spring rate...
He is doing something wrong or he doesn't have a 14" 150lb spring. I was running 14" 130lb springs in my black car and it weight 3016 with me in it. 14" 130lb spring is the most common spring out there and many people are using it with weights ranging from 3000 to 3300 pounds. Your friend has issues somewhere else.
ok thnx alot..
what brand should i go with???
Just get a coil over kit for your struts. UPR, Granatelli and other companies make them. The kits usually come with some stiff springs so you will probably have to buy another set of springs which is about $50 if I remember correctly.
Zip Your my Hero....
1988 Mustang LX
N/A
thats 5
Don't be whoring up threads just to get your post count up so you can post in the classifieds or I will make your posts disappear. Participate in conversation and you will get post counts.
Thank you and have a nice day.
Threads Similar to: coil overs!?
| coil overs | don | General Tech | 1 | May 13th, 2008 12:01 AM |
| Coil Overs | MustangMatt96GT | 96-98 | 16 | December 25th, 2007 12:32 AM |
| Coil overs | singe | General Tech | 5 | October 25th, 2007 02:04 PM |
| Coil-overs, where? | energiesource | 99-04 | 37 | August 29th, 2007 06:47 AM |
| Coil overs | stanglover99 | General Tech | 2 | July 16th, 2007 04:36 AM |
