Just got a new 5.0 and I'v got problems - Page 2
Old October 2nd, 2008, 11:07 AM   #21
BORDEN's Avatar
91 lx convt
14.02@100
BORDEN is on a distinguished road
Originally Posted by Wilkins View Post
I dont know where to start. Ive never really dealt with FI engines before so im a little lost. any insight would be greatfully appreciated!
1) Its got a really nasty cam and sounds amazing at about 7-800 rpm, but at idle, the car will stay at about 800 rpm for a few seconds and then rev up to 1100 for a few seconds for no reason at all and then back down to 7-800. This one has got me baffled
2)Crusing down the highway, the temp stays at about 180-185. But if you have to stop at a light for too long or go through the drive through, it will easily get up to 210-215. But 2 mins of driving will cool it right back down. But the fan is spinning. If i hold it at 1500 while at a red light, i can maintain my temp.
3)Car isnt charging correctly. Battery gauge never goes over 11v-12v, even at 3000 rpm. It has a brand new high output alt and a optima red top battery.
So i cant turn it off or else it might not start again. Cant leave it running or it gets a little warm.
HELP!!!!
1) vacuum leak more than likely
2)5.0s run hot. the reason it is lower while your moving is the wind is cooling it down. put a 180 thermostat on and an electric fan.
3)I went threw three alternators before i found one that worked. i would check to see if you have U/D pullies if you do then just take em off and but some stock one on.
Old October 2nd, 2008, 11:22 AM   #22
ryans88gt's Avatar
Originally Posted by 95blackbeauty View Post
I had a rolling idle like that and it would go up and down then die. My problem ended up being insufficient Fuel injectors, went to 24# injecs and its been fine ever since.
That is very very unlikely. More likely that your stock MAF was giving a faulty signal and when you swapped injectors, you swapped out the MAF....or one of your stock injectors was intermittently getting stuck.
Old October 2nd, 2008, 01:45 PM   #23
Hunt_chevs's Avatar
2002 Gt
Not Slow
5.0 Base Idle Reset
2. check/clean you battery terminals (improper connection can cause poor charging)
Threads Similar to: Just got a new 5.0 and I'v got problems
Problems adrenaline=lifeline 99-04 3 August 25th, 2008 04:20 PM
Few Problems Please Help nHuman 96-98 1 May 10th, 2008 04:10 PM
a/c problems quick96cobra 4V / SVT 2 May 4th, 2008 04:00 PM
5.0 problems 5.0Madness 5.0 Mustangs 1 March 11th, 2008 07:39 PM
V6 Problems Bies08 V6 Mustangs 16 March 22nd, 2007 12:59 AM
