Discussing Engine IDentification in the 5.0 Mustangs Forum. A few questions, how exactly can you tell a 302 and a 351w apart? I ...
Old December 3rd, 2006, 10:21 PM   #1
A few questions, how exactly can you tell a 302 and a 351w apart? I know the deck heights are a little bit different with the 351 being like 9.5 or so, but is there any other tale tale signs without removing the valve cover? Because a 351 will ahve it engraved in the valley.
Also will a 302 double sump oil pan fit the 351?
Thanks
Chuck
Old December 3rd, 2006, 11:37 PM   #2
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Depending on when the engine/vehicle was built, another way to tell the 351W apart from the 289/302 in most cases is the number of intake manifold to cylinder head bolts. The 289/302 has 12, the early 351W (pre 1976) has 16. Other differences between these similar looking engines are main bearing diameters 289/302s measure 2.25 inches, 351Ws are 3 inches slightly larger. Rod journals measure 2.12 inches compared to 2.31 inches, and the fact that the 351W uses a longer connecting rod 5.95 inches compared to 5.15 inches for the 289 and 5.09 inches for the 302. Hope that helps!
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old December 4th, 2006, 02:06 AM   #3
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The intake on a 351W is noticeably wider than a 302. Block casting numbers will tell you too. 302 oil pans will not work on 351Ws.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Threads Similar to: Engine IDentification
Lifter tick identification wanabebuff 5.0 Mustangs 15 June 12th, 2007 08:02 PM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 06:53 AM
Block identification hubba076 99-04 3 May 27th, 2007 03:45 AM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 06:09 PM
351 W head identification 351confused The Clubhouse 3 February 12th, 2007 07:05 AM
