Intake vacuum help
Old September 18th, 2008, 11:06 PM   #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Intake vacuum help
can any one tell me where the hose that im holding goes? its been a long night and I dont want to read one of these
http://www.veryuseful.com/mustang/te...g5.0Vacuum.gif
Old September 19th, 2008, 12:41 AM   #2
1992 Lx
11.39@119.24
vacuum tree? pcv valve? looks too big to go to the fpr
Old September 19th, 2008, 12:56 AM   #3
Could be many things....you can hook any vacuum line to anywhere....
either pcv or brak booster t
PeteAndersonRacing.com
Old September 19th, 2008, 02:19 AM   #4
Holy Dick Castle!
dr.gonzo!'s Avatar
I dont think it goes to the the pcv valve because there is a plastic piece on a diffrent hose that fits in the lower intake manifold.
and I know it dosent go to the tree becuse ther is another hose that goes there.
this one has me stumped and I dont want to cap it off and start the car and find out that I have to pull this shit off again. but I have looked for hours trying to find what this hooks too.
it has a curve in it hooking upwords but theres no way it will reach the vacuum tree.
where is the brake booster?
Old September 19th, 2008, 08:46 AM   #5
Holy Dick Castle!
dr.gonzo!'s Avatar
bump
Old September 19th, 2008, 11:48 AM   #6
1989 Ford Mutang LX
Wilkins is on a distinguished road
the brake booster is on the driver side firewall. Its the big round thing that your brake fluid reservoir is connected to.
Old September 19th, 2008, 11:58 AM   #7
Hunt_chevs's Avatar
2002 Gt
Not Slow
those are the ones facing the firewall?
Old September 19th, 2008, 12:04 PM   #8
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
Mine didnt have anything on there, it was capped
And vacuum to brake booster goes from the vacuum tree
Originally Posted by FX4DTUF View Post
a camaro pulls up next to me and i think to my self what would jesus do at a time like this then it hits me he would launch it and power shift the shit out of it
Old September 19th, 2008, 12:13 PM   #9
Hunt_chevs's Avatar
2002 Gt
Not Slow
mine has a boot there as well, but there is a hard line that connects to here
Old September 19th, 2008, 12:14 PM   #10
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Gonzo is your car sd? If yes, then its probably going to MAP, and that would explain why mine was capped.
Old September 19th, 2008, 12:19 PM   #11
Hunt_chevs's Avatar
2002 Gt
Not Slow
yours is not sd? because mine is not and it has that booty
Old September 19th, 2008, 12:46 PM   #12
Holy Dick Castle!
dr.gonzo!'s Avatar
I think I found it. I think it goes to that black box to the left of the tree. (the one with the old yellow sticker on it.) it plugs in from under neath.
I finnaly got it to run 40 psi fuel timing is at 14deg but I have a lot of white smoke coming out of exhaust and it kinda smells sweet.. wtf is that about?
Old September 19th, 2008, 01:47 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Does it go under the upper intake toward the front of the car?
Old September 19th, 2008, 01:48 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is the MAP sensor. You only need a vacuum line on that sensor if your car is a speed density car. If your car is a mass air car then absolutely do not connect a vacuum line to that sensor.
Old September 19th, 2008, 10:58 PM   #15
Holy Dick Castle!
dr.gonzo!'s Avatar
No I still am sd and thats the way I hooked it up. the car ran a little rough after bolting up the upper intake. I set the timing and it ran good for a little while next thing I know the radiator is empty and I have a shit load of smoke coming out the back and my exhaust is holding most of the antifreeze
this is the way I hooked it up please tell me if Im right. Im going on day 3 w/o my car and I need my fix lol
Also I replaced the stock fuel pressure regulator with an adjustable one so what do I do with that red vacume line? there is a screw now
Old September 19th, 2008, 11:06 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
By chance is coolant leaking thru the EGR spacer? Are the EGR spacer coolant lines hooked up?
The vacuum line must be hooked up to the fuel pressure regulator. Whether it is adjustable or not means nothing.
Old September 19th, 2008, 11:47 PM   #17
Holy Dick Castle!
dr.gonzo!'s Avatar
I just dont see a place too hook it up at. just put in over the screw?
and I dont know if it was leaking from the egr but I did see some coming out of the throttle body. and I did have to use some pretty good force to get the throttle body off becuase of the corrosion. do you think the egr can crack and cause that?
Old September 20th, 2008, 12:06 AM   #18
sweet smelling white smoke normally means a coolent leak like a head gasket etc.. might want to confirm that the coolent is coming from the egr spacer and replace the gaskets as needed.
what brand of afpr did you buy? holley? all afpr have a vacuum port on them
Old September 20th, 2008, 12:09 AM   #19
fogged306's Avatar
89 GT
Sounds like the EGR is leaking. Easy way to tell is to bypass the collant lines temporarily and see if you are still smoking. I wouldn't leave it like that if the EGR is still functioning though, I've never tried it personally, but I would assume it might get hot enough to damage something eventually.
Old September 20th, 2008, 12:17 AM   #20
Holy Dick Castle!
dr.gonzo!'s Avatar
I did a compression test and all were 175-180 except for #4 cyl was 160.
Threads Similar to: Intake vacuum help
Vacuum lines on Explorer intake????? b-on-b 5.0 5.0 Mustangs 1 August 26th, 2008 08:02 PM
Questions on vacuum set up on Explorer intake?? MonsterSD 5.0 Mustangs 1 August 17th, 2008 10:47 AM
engine vacuum 65 B/FX 5.0 Mustangs 3 March 19th, 2008 02:30 PM
vacuum... sivart 5.0 Mustangs 22 July 31st, 2007 11:02 PM
Intake/vacuum FiveOOH89 5.0 Mustangs 3 July 28th, 2007 06:19 AM
