carb ?
why do you lose power when switch to carb? will a tall runner manifold give the low end torque like an efi manifold? or even tall runned with 2 four barrels?
85 svo. work in progress
You wont lose power if you get the parts to make more HP. You can gain power by getting less restrictive parts that are more tunable. Cant tune with stock EFI, and throttle bodies are small.
#3 | |
Re: carb ?
#4 | |
well hopefully ill be gettin a reman long block from ford and im considering carb but alotta people on here say carb will lose power. my ultimate goal is to have a clean, simple, engine compartant(like the idea of carb sitting on a tall manifold) but i only wanna gain power not loose any
reman long block + carb and manifold = hp,tq?
#6 | |
is 250hp max because of stock heads
Typically on a stock or mild engine EFI will make more torque and power across the rpm range. Peak horsepower might be a bit higher with a carb but over all you will see a loss.....on a dyno anyway. On stuff that is more heavily modified it is easier to go faster with a carb. There are guys making big numbers with aftermarket EFI systems but you have to find someone that can tune them. On a car that is mostly a street car I'd never take the EFI off. Been there, done that, won't ever do it again.
If the heads were that restrictive there would be no need for small exhaust, catalytic converters, & a small throttle body.
#10 | |
#11 | |
. FYI, the heads are very restrictive, but the air silencer, MAF, and lower intake are the most restrictive, followed closely by the stock 4-cat h-pipe. without changing heads 250 is likely the most you'll get out of it. with ported "thumper" E7s (ported stock heads) the most i've ever heard of anyone getting is 285hp (obviously without power adder)
#12 | |
Threads Similar to: carb ?
| CARB OR EFI | BLACKNIGHT5.0 | 94-95 | 10 | August 16th, 2007 03:39 PM |
| efi to carb please help | itsmyfiveoh | 5.0 Mustangs | 33 | June 20th, 2007 02:26 PM |
| carb to efi | 347tt | 5.0 Mustangs | 5 | February 11th, 2007 08:08 PM |
| To carb or not to carb? | MSO | 5.0 Mustangs | 14 | December 9th, 2006 12:33 PM |
| V6 EFI vs Carb | quikstang2 | V6 Mustangs | 3 | August 17th, 2006 06:19 PM |
