Discussing Harmonic Balancer in the 5.0 Mustangs Forum. I had to change out the balancer because it was loosing the rubber in the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1991 MUSTANG GT
Harmonic Balancer
I had to change out the balancer because it was loosing the rubber in the center. I put it back on and it was easy. My question is it supposed to go on like a chevy or does the 80 foot pounds keep it there?? I really don't want to loose it while i'm driving it. I am used to beating on a chevy balancer. Mark
Asshole™
1990 Mustang LX
9.36@143 mph
You shouldn't every beat any balancer on. You risk damanging the balancer, crank and bearing by doing that. They make a tool for the job, its called a "harmonic balancer installation tool". Just like a Chevy there is a key on the crank. The groove in the balancer must slide over this key and then the bolt goes in. Alot of the time you can push the balancer on far enough and then use the bolt to draw it in the rest of the way.
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
1989 Mustang LX
10.98@126.7 NA
70 - 90 ft lbs will hold it provided that it is all the way on. You did use a harmonic balancer installer, not a hammer, right?
Never fast enough.
1991 MUSTANG GT
Balancer
I never beat on a balancer with a hammer. We always use a 4x4 block and a rubber mallet. The one on my fox slid way on and mu chevy's are super tight. Is there a way to look at the balancer and tell if it's on all the way?? Anyone have a pick??
Asshole™
1990 Mustang LX
9.36@143 mph
Hammer or rubber mallet doesn't make a difference. Its the jolt every time you whack it that does the damage. It would be wise to never do that again.
FYI, it is a bad idea to hit the balancer to get it on, use the install tool. HOWEVER, Ford does mention in the installation instructions of their Ford Racing balancer that you can tap the balancer with a block of wood or aluminum with a hammer IF you heat the balancer by boiling it in water (15 min) or putting it in the oven @ 150-200 for 15 min and not letting cool before it's fully installed with the bolt.
Threads Similar to: Harmonic Balancer
| harmonic balancer | chickenbot | 5.0 Mustangs | 3 | May 17th, 2008 06:35 PM |
| Harmonic Balancer | shurb125 | 5.0 Mustangs | 14 | December 3rd, 2007 02:01 PM |
| Harmonic Balancer | dreamr | 5.0 Mustangs | 9 | October 30th, 2007 09:54 PM |
| 89 5.0L harmonic balancer | Rutcutter | Want to Buy | 0 | June 9th, 2007 11:33 PM |
| Harmonic Balancer | Fastpitchdad | Engine | 0 | February 19th, 2007 03:21 PM |
