valve lash
LinkBack (1) Thread Tools
Old September 19th, 2008, 07:40 PM   1 links from elsewhere to this Post. Click to view. #1
-Joeyy- is an unknown quantity at this point
Send a message via AIM to -Joeyy-
valve lash
I adjusted the valves on my stang today and it was running mint then the next day i took it out and it felt like shit again so i took the valve covers off and the rockers tightened up rly stiff. i figured it was because it got hot and they tighten up so i readjusted them once the car was running for 30 mins. maybe i dont have solid lifters?
Old September 19th, 2008, 08:49 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
They will be stiff due to spring pressure and lifter preload.
Old September 19th, 2008, 09:12 PM   #3
the stiffness means that they are fucked up again tho doesnt it?
Old September 19th, 2008, 09:25 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No it doesn't. If they were loose then it would be improperly adjusted. If you don't know how to do adjust lash then you shouldn't be doing it.
Old September 19th, 2008, 10:01 PM   #5
i learn by doing it myself
and i know for a fact with how tight they are geting the exhaust isnt opening enough causing my motor to run bad and when i adjust it it runs mint ( i make it a little loose ) but then it tightens after warming up making it run like crap
Old September 19th, 2008, 10:43 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Just by reading this post I can tell that you do not know how to adjust lash properly nor do you understand the function of the valve train components. There is a topic somewhere on this site that discusses valve lash. I believe it is one of the sticky posts.
Old September 20th, 2008, 08:52 AM   #7
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Any of the cam manufacturer's sites will have detailed instructions on how to set valve lash. You need to know whether you have a solid or hydralic lifter cam as well as the cam manufacturer's specs for hot and cold lash. Sounds like your taking a guess at everything. Nothing wrong with learning as you go as long as you learn the right stuff.
Never fast enough.
Old September 20th, 2008, 12:15 PM   #8
i am guessing because i dont know what i have. im bringing it to a shop to get tuned friday.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/89581-valve-lash.html
valve lash This thread Refback October 8th, 2008 09:34 AM
Threads Similar to: valve lash
Valve lash Adjusters interfac9 99-04 31 September 18th, 2008 05:59 PM
Valve lash plz help FAST -Joeyy- 5.0 Mustangs 4 September 17th, 2008 10:51 PM
Valve Lash Adjustment IcantDo55 5.0 Mustangs 6 April 2nd, 2008 09:50 PM
Valve lash adjustment shurb125 5.0 Mustangs 8 March 10th, 2008 09:52 PM
valve lash terribleonexx88 5.0 Mustangs 9 March 8th, 2008 12:40 AM
