98 Cobra
how to improve heater strength and temp?
so i finally got my dash blowin air but its not that strong and my heater isnt that hot so how can i improve it?
89 GT
You got enough coolant? Are you using a low temp thermostat?
98 Cobra
yes on the low temp thermostat
#4 | |
Put a 192 degree thermostat back in it. The temperature of the heater is controlled by engine heat. A low temp thermostat does not produce much heat, not to mention it doesn't benefit you in the least bit as far as horsepower is concerned
98 Cobra
i knew it doesnt give hp gains but that it was supposed to increase the live of the engine? also how can i make it blow stronger?
93 GT N/A 302 H/C/I
6.73@101.7--- 10.59@126.06
Get a 16 volt batt. LOL!
N/A 302 Pushrod Power ![]() |
1989 Mustang LX
10.98@126.7 NA
Make sure that the actuator for the flap in the heater box is moving all the way and not sticking. These are vacumn operated.
Never fast enough.
#8 | |
As far as blowing stronger goes, a new blower motor might be the only cure for that. Its hard to tell without seeing it. Or a 16 volt battery like Pure Stock said LOL!
98 Cobra
as far as the battery, im running a red top altima battery, that should do the job shouldnt it?
Threads Similar to: how to improve heater strength and temp?
| block strength | 95wip | 94-95 | 0 | May 21st, 2008 04:08 AM |
| Can ur senses improve? | G.T. Rags | The Clubhouse | 8 | April 10th, 2008 01:43 AM |
| 15.5 mpg - How can I improve this? | Disturbed One | V6 Mustangs | 20 | February 16th, 2008 08:24 AM |
| AC & Heater now that it is winter, my heater doesn't wor | Kingcater | 5.0 Mustangs | 13 | January 22nd, 2008 12:33 AM |
| Can this improve performance? | stagecrewgod | V6 Mustangs | 7 | April 5th, 2007 05:00 AM |
