LinkBack (1) | Thread Tools |
#21 | |||
This guy needs to disclose more info on the problem and the set up....... and what valves are hitting (exhaust or intake)........could be cam timing or worn stock valve springs (floatin a valve) .......but we dont know exactly what happened........ I just dont get how he did it twice................ ![]() ![]() ![]() ![]()
PeteAndersonRacing.com |
#23 | |
Your friend's Firebird comparison is not a valid one. You are talking about a car that has a ton of race oriented work done to it versus a car that is basically stock. Three things will bend pushrods - 1. valve spring pressure and 2. valves hitting pistons. 3. Valvetrain locking up (coil bind, etc.). Your friends Firebird obviously didn't have valve to piston clearance issues since the car ran after you changed pushrods and valve springs. You said the proper springs were not installed so that makes the answer pretty obvious, coil bind caused the push rod failure. Now if he did use the correct springs its possible you would have had pushrod failure then as well if he had any kind of aggressive camshaft that required high spring pressure.
#24 |
How long have you been a technician and who told you that .500 lift is the magic number? Lift really doesn't cause the clearance problem. Its the timing events (when the valve opens and when the valve closes) that cause the issues.
#25 | |
Since 1995. Now I work on big rigs. Parts got bigger and heavier, and the pay got WAY better than flat rate would ever be. And my instructors didn't say .500 was the magic number, they said that problems start there, depending on the application. Some engines more than others. Some engines can take that much lift in stock form, others can't. On another note...what kind of head gasket is being used? What's the compressed thickness? Copper? MLS? Fel-pro? |
#26 |
I forgot to add in my previous post that your statement "Ford Senior Master Technicians and ASE Master Techs are very seldom wrong" I hope was a joke. I have a stack of ASE certifications from years ago and none of them mean anything. They sure did look good hanging on the wall though. When I went in and took those tests I laughed my ass off. The tests are so simple (especially the ASE tests) that anyone with any mechanlical inclination can pass them.
And no I don't mean any offense, I just hope that was a joke comment.
#27 | |
#28 | |
I also cook.
#29 |
.500 lift magical number lol.........
What if you had a .300 total lift and big duration with all the valve events off....what then.... Where can i get my certification ? Cracker jacks box?
#30 |
#31 | |
Cooking gets the women from what I hear.
#32 | |
I always wanted the money instead of the certifications. Certifications weren't making the monthly payments on my Mustang back then. They ain't worth a damn to a pawn shop.
#33 |
1990 Mustang GT
13.64 @ 101 MPH
i knew a guy who copied somebodys to his computer and then put his name on em......and didnt know how to do nothin. if you dont know how to turn a wrench even if you have the paper you still wont make any money
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
#34 |
1988 mustang gt
hey mother fucker fuck you i did it once and was askin advice so blow me
#35 | |
#36 |
lol, this is crazy.
#37 | |
#38 |
12.9 @ 105
I used to try and ask our Master Tech about my car which is a basic H/C/I setup when I had problems and he said if it wasn't stock he didn't know about it. I would never get a straight answer from this guy.
#39 |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/89722-hell-302-a.html
| Funny Blog » Blog Archive » to hell with this 302 | This thread | Pingback | September 21st, 2008 12:43 PM | |
Threads Similar to: to hell with this 302
| 302 xxx block VS. 302 yyy block?? plz help | 00SoSlow | 5.0 Mustangs | 13 | July 29th, 2010 01:57 PM |
| what the hell... | thetrooper31 | The Clubhouse | 28 | April 21st, 2008 06:52 PM |
| Help carb'ed 302 /efi 302 | sins23 | 5.0 Mustangs | 5 | September 10th, 2007 09:26 AM |
| Difference in a BOSS 302 and a 302 | fordboy4rd | 5.0 Mustangs | 40 | March 18th, 2007 10:52 PM |
| Weight of Dart sportsman 302 compared to stock 302 | painfully slow | 5.0 Mustangs | 3 | February 23rd, 2007 04:47 PM |
