7.5" to 8.8" rear end swap help...
LinkBack (1) Thread Tools
Old September 21st, 2008, 10:30 AM   1 links from elsewhere to this Post. Click to view. #1
NELLY97Cobra is on a distinguished road
Hey everyone, I have a 97 mustang V6 that Im working on and needed to know if the fox body rear end will bolt up to the sn95 and if my axles and brake system will fit. I really dont want to spend too much on getting a 5 lug conversion kit for it so I was hoping the axles i have on the 7.5" fit the 8.8". Thanks in advance!
Old September 21st, 2008, 11:21 AM   #2
demonicus's Avatar
1988 mustang LX coupe
demonicus is on a distinguished road
should have bought a complete 8.8 and sold the 7.5
I dont think they'll work.
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars
88coupe- lookin for a new powerplant
Old September 21st, 2008, 03:57 PM   #3
fairlane_68 will become famous soon enough
The Fox 8.8 is narrower by 1.5 inches. You'd be better off with a 8.8 out of another SN95...they're a dime a dozen. Or you can either run wider wheels with an offset, or look like a cornball with a funky rear end.
Old September 21st, 2008, 07:14 PM   #4
Thats exactly what I wanted to do but I got a good deal on a T5 tranny and rear end from a Fox. I dont mind running wider wheels with a different offset. Thats one of the last things Im doing and I want them to look nice along with the paint. But I was wondering if the axles that I already have fit the 8.8" so I can just swap everything to the new diff.
Old September 21st, 2008, 08:01 PM   #5
fogged306's Avatar
89 GT
I could be wrong here too, but I think the trans is different between the fox and the sn95. I believe the input shaft is longer on the sn95 trans... e3sean?
Old September 21st, 2008, 10:25 PM   #6
No. Your 7.5 axles will be too long, and I believe the spline count will be different. I think the 7.5 is a 28-spline, and the 8.8 is a 31. I could be thinking of the truck 8.8, which I know is a 31-spline.
Old September 21st, 2008, 11:48 PM   #7
1986 LX
none yet
jtyson8602 is on a distinguished road
axles should be the same spline count but too long i think
Old September 22nd, 2008, 06:45 AM   #8
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Input shaft IS longer on SN95s
Never fast enough.
Old September 22nd, 2008, 12:19 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Won't work for your car.
Old September 22nd, 2008, 12:20 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Standard Mustang 7.5 and 8.8 rear ends are 28 spline.
Old September 23rd, 2008, 08:09 AM   #11
Thanks guys, I found a diff from a 95 Cobra so I dont have to go through the headache. I got it from a local junkyard for $350
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/89723-7-5-8-8-rear-end-swap-help.html
7.5 This thread Refback November 2nd, 2008 12:04 PM
Threads Similar to: 7.5" to 8.8" rear end swap help...
8.8" rear end measurements... Ted J 5.0 Mustangs 14 August 8th, 2011 07:05 PM
8.8" rear end... singe V6 Mustangs 7 July 26th, 2007 05:40 AM
9" rear end 69_5.0_stang Classic Mustangs 2 July 26th, 2007 05:25 AM
7.5 or 8.8" Rear End In My Car? CyberPrey V6 Mustangs 18 October 29th, 2006 11:55 AM
