subframe connector install???????
i have subframe connectors(weld on)..... i kno someone who can weld pretty good. is there anything that can be messed up while puttin them in? like if there off by a inch or something. or is it pretty much align the front and rear subframes and weld them up???? any advice is appreciated...
line them up and weld them in. Just make sure you clean the metal on the car real good so you get god penatration. Not really any way to mess it up.
Make sure the weight of the car is on the wheels when you install them as if the car was sitting on the ground. That is very important.
thnx alot guys!!!!
91 Mustang LX Fastback
We shall see when she gets done..
Ya for sure, I welded my car in the air, im waiting to see how much it pulls to one side.
Brett!
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts 1991 LX. 2.3T in the works. 1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown ![]() 1969 Impala. Needs a resto. Im Canadian, Eh! |
Well, how much do you think it flexed??
I had the arms out pretty far to even out the weight so it would try and act as if weight was on it... Ill get the car going, and I find the car is pulling hard im going to cut them out, and do some more sturdy threw the floors ones.. Brett!
#8 | |
1989 Mustang LX
10.98@126.7 NA
Same thing holds true for putting in roll bar / roll cages.........
Never fast enough.
Darrell, you think it will really be that bad??
I know its like that for cages, but than question, I wanna get a 6pt done soon, should I wait to see if the car pulls before I get a cage welded into it?? Brett!
i would redo the subframe connectors before you think about a cage
Maybe ill chop them out in the spring and just do up some threw the floor ones..
Will I have seat clearnace issues if I do that?? Brett!
I'd redo it immediately if it was my car.
Everything on my car lines up really well..
Doors shut fine and everything, it dosent look like the car is even slightly twisted.. Brett!
Good. I had an '84 GT that was so bad, I had to pick the car up to get the sub connectors to fit. I welded them to the front, and the rear of the connector was 8" below from the rear frame. Once the connectors were in place, not only did the doors shut like they did when the car was new, but the T-Tops sealed much better. That car also had cracks in the floor.
#17 | |
87 Mustang GT T-top
Yeah why risk it, it shouldnt take that much time, just a day project if all goes well. And from what everyone is saying well worth it. |
So, with my doors and everything lining up correctly, does it sound like the car is relatively straight..??
I mean, they still close just as well as they did before I put them on.. Brett!
Threads Similar to: subframe connector install???????
| help need 10 pin connector | Iownastang | 5.0 Mustangs | 8 | September 20th, 2008 03:15 AM |
| OBD2 Connector Location? | Wilkins | 5.0 Mustangs | 3 | September 17th, 2008 11:42 PM |
| Sub Frame Connector ?? | 08 Vegas GT | 4V / SVT | 8 | September 3rd, 2008 04:51 AM |
| Sub Frame Connector ?? | 08 Vegas GT | 99-04 | 5 | September 2nd, 2008 07:38 PM |
| Jack Stands on SubFrame Connector | sdonaghey | 2005 - 2010 | 1 | March 12th, 2008 04:26 PM |
