clutch or trans problem?
Old December 4th, 2006, 10:16 PM   #1
blackcherry90 is on a distinguished road
i have done a aod to t-5 swap all parts are new except trans was rebuilt.new flywheel,spec 1 clutch,triple hook quad with adjustable cable and firewall adjuster,new clutch fork and throwout bearing.after the swap first try clutch would not disengage no matter how much adjustment was done.tried different clutch same problem.changed cable to stock replacement and still same thing. can anyone tell me what problem might be,running out of ideas
Old December 6th, 2006, 10:22 AM   #2
did you install the clutch disc backwards?????
88 Mustang Coupe
www.rickscarcare.net
Old December 6th, 2006, 03:28 PM   #3
yea that was one of the first things i checked thought i might have had a duh! moment when installing thanks for the reply
Old December 6th, 2006, 11:39 PM   #4
83 5.0's Avatar
83 5.0 is on a distinguished road
Is the pressure plate the correct unit? 10" or 10.5", when the cable isn't connected the clutch lever should have some play and not feel it is upagainst the fingers on the pressure plate.
Old December 8th, 2006, 12:27 PM   #5
It's a ten inch and there is some play before you connect cable.I got a tip this week on the pilot bearing if it's not installed dead flat or not machined correctly to where inside dia. is true it will give the trans a direct drive and not let the clutch disengage finally found someone who had similiare problem so i'm going to buy a stock replacement from ford and give it a try the throwout bearing was a little sloppy when i got the clutch so maybe they have problems with pilot bearing also keepin my fingers crossed i'll put up a new thread if it cures the problem thanks for the info.
Threads Similar to: clutch or trans problem?
clutch problem rob madison 96-98 5 October 26th, 2007 11:06 AM
Auto Trans Problem - Stuck in Park on my AOD Sir Charles 96-98 10 July 10th, 2007 11:03 PM
Trans. problem?? McCallister 99-04 28 April 7th, 2007 09:23 PM
Trans Problem 97what? V6 Mustangs 0 September 10th, 2006 07:29 AM
clutch, trans, gears...? jorstang 96-98 5 June 21st, 2006 02:14 AM
