high compression question
dont flame i just want to make sure about this. My mustang is high compression am i able to add a turbo or supercharger and is a blower different then a supercharger? please give me brand names of stuff that i can add if there is any. thanks
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
when you say high compression...what is the actual compression ratio?? and what set up raised the compression from stock (I.E. pistons,rods,cam,etc.)
1987 ford mustang gt
well see when shes done
What is the C/R?
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#4 | |
No, a blower or turbo will not work with a high compression engine.
how do i find out the compression ratio? i can do a compression test and post the results if you guys want. and yeah darrel its the same motor.
A compression test will not net enough information to compose a theoretical compression ratio. You will need much more than just static cylinder pressure.
A cranking compression test has nothing to do with the compression ratio. To figure the compression ratio you will need to pull a cylinder head off and you will need some accurate measuring devices. You will need to know bore, stroke, head gasket compressed thickness, head gasket bore, piston height in relationship to the deck surface, piston dome or dish volume, volume above top piston ring and combustion chamber volume.
1989 Mustang LX
10.98@126.7 NA
You need to know bore, stroke, piston deck height, head gasket thickness, piston dish / dome volume and combustion chamber size to figure CR
Never fast enough.
MM's Ford Truck Guy
99 ranger,2010 ranger
does nice burnouts
![]() 1999 xlt 2.5 ranger lowered 5/6 on 17in bullits 2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits |
#10 | |
blah what can i actually figure out about my motor with out tearing it apart? lol i am putting it on the dyno friday and ill post the results then maybe you guys can tell me what it possibly has done to it.
MM's Ford Truck Guy
does nice burnouts
how is that wrong
i have always used that formula for all my builds and it hasnt failed me once, i was taght that from a guy who has been building motors for over 35 yrs he is 66 now and still doin it
1990 Mustang GT
13.64 @ 101 MPH
your gonna have to tear it down or find out from whoever put it together. dont be surprised if you pop the head off and the pistons are stock. unless they changed pistons the only other way would be smaller comb chamber either with diff heads or stock ones milled down. you gotta take it apart or dont worry bout it.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
1989 GT
KB 2.1L Flowzilla
It gives the same c/r for -18cc dome and +12cc dish. You dont think that makes any difference?
It doesn't add up for me. I've run a couple different combinations thru it and come up with lower compression then what the engines actually had.
1988 lx
9.68@142
we cant tell u anything internal without opening it. why dont you find the guy who built it and ask him.
2000 mustang GT
tear it down and whie your at it stroke it
MM's Ford Truck Guy
does nice burnouts
ok well idk then thats the formula i was taught by him and in my tech school
Threads Similar to: high compression question
| is 10.5:1 compression too high for a supercharger? | 94' Cobra 351 | General Tech | 33 | May 5th, 2008 08:05 PM |
| High vs. Low Compression | 87StangLX | General Tech | 14 | November 17th, 2007 10:42 PM |
| A Question About Prochager With High Compression | blue03mach1 | 99-04 | 15 | November 9th, 2007 02:46 PM |
| High Compression and FI | blk98gt | 96-98 | 6 | July 3rd, 2007 10:27 AM |
| compression too high for a supercharger? | 94' Cobra 351 | Drag | 3 | January 10th, 2007 11:05 PM |
