Edelbrock Rpm Intake
Old September 25th, 2008, 01:11 AM   #1
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
I just won a new in the box preformer rpm intake for my fox for just under 230.00 dollars. What is the difference between the rpm and the rpm ll intak as far as preformance goes??? Is that a good deal for an older intake thats new??? I am goin to buy afr 165 heads and leave my stock cam in her, will that combo work good or would a cam be a better combo?? I am looking to make her faster for the street. Thanks Mark
Old September 25th, 2008, 02:19 AM   #2
1992 Lx
11.39@119.24
the rpm is good up to 5500 and the rpm 2 is for higher revving engines if i remember correctly
Old September 30th, 2008, 06:40 PM   #3
BLUE91GT's Avatar
Intake
So does that mean it is a good street intake, or is it more of a track intake. I am planing on buying afr 165's soon, so if I need a cam I want to do it all at once. What would be a good street cam? Id like to see around 350 hp! If that's atainable. Thanks Mark
Old September 30th, 2008, 07:03 PM   #4
1998 Cobra
13.24@105.66
trickflows would flow well and cost 500 bucks less than those afrs..
weeee foooord!
Old September 30th, 2008, 09:26 PM   #5
1987 ford mustang gt
well see when shes done
How do you get afr 165's are 500 bucks less than trickflows.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old September 30th, 2008, 09:49 PM   #6
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
He said TFS is cheaper than AFR
The TW's do cost about $300 less, but you have to keep in mind the AFR's
come fully CNC'd right out of the box, while TFS heads will be cast ports.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old September 30th, 2008, 11:06 PM   #7
Dang!! i did it again. I said my statement wrong i meant to say more instead of less.
Old October 1st, 2008, 09:23 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That intake is much better than the stock intake. $230 is a good deal. I'd pass on the AFR heads and get some Twisted Wedge heads for less money and they flow better than the AFR 165s across the board. Canfield's are another option.
Old October 1st, 2008, 01:21 PM   #9
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Get a cam while your down their, other wise you will regret it.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old October 2nd, 2008, 10:53 PM   #10
tmoss's Avatar
tmoss is on a distinguished road
Stock the RPMI flows about 230cfm and the RPMII flows about 260cfm. Once ported, they will flow right at the same - 275-280cfm for a min cross section of a 1250 size runner. The RPMI has shorter runners. Both good intakes.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Threads Similar to: Edelbrock Rpm Intake
edelbrock intake bigmike83 99-04 0 March 7th, 2008 06:37 PM
New Edelbrock 2v Intake suprajay79 99-04 2 March 5th, 2008 04:53 AM
Edelbrock Intake suprajay79 99-04 0 February 29th, 2008 05:40 AM
