LinkBack (1) | Thread Tools |
#1
problems at the track
i have a 1993 gt with the following mods
bbk longtubes o/r x Mac catback bbk cold air msd dizzy 12 deg. timing qa1 k-member toikico/granatelli coilovers granatelly tubular control arms granatelli rear upper and lower controll arms tokico springs strange adjustable shocks eaton posi with 31 spline axles 3.73 gears. my best was 15.088 with a 2.44 60' and a .742 reaction time. I was burning through 1st and most of second and my rear shocks were set at super stiff, not for drag. wind was against us. what should my time be and how can i launch harder and still hook. I am hoping for a high 13's. Thanks for any help |
Needs a driver mod and some tire............
PeteAndersonRacing.com |
thanks alot? i got the shifts down flwless.it was my first time running the car at the track. im not used to staging the lights. I def need to work on my reaction time. the tires are 275-45-17 goodyear eagle f1 with 35#. what shoul my time be?
Reaction time has no effect on your times..... get some real tires....stop ridin on ice at the track
1986 lx notch
9.98 @ 135
+ 1 on the driver mod > : 0 )
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
1990 mustang gt
n/a
check out "mustang performance handbook 2" by william r. mathis. It has alot of great info on setting your car up, and if you have the ability or know someone who does, there are many pieces that can be fabricated. One trick to help increase antisquat and send more of that power to the ground is to change the angle of your pinion. You also need to make sure your tires are up to the task.
1989 Mustang LX
10.98@126.7 NA
2.44 60? I had a Pinto that would do that. Seriously, get some better tires for drag racing(run less that 35#) and go practice. Reaction time has nothing to do with the rest of the facts. You can sit there for 2 seconds, the rest of the times don't start until you move. Spinning tires = going no where fast!
Never fast enough.
#8 | |
However, with some practice you should be able to click off some 13.90s-14.0s even with those tires. Your 60 foot is horrible. Get it down to 2.0 or better. If the tires are spinning off the line so bad then obviously you need to take off a little easier. Work on your launch technique and your ET will improve drastically. The majority of your ET is gained in the first 330 feet. Changes in the 60 foot will be the biggest improvements in ET.
1993 5.ohhhh
12.97 @140mph
What was your mph?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1990 LX hatch
^+1 that is the only question. We will be able to give a good estimate of what the car should run.
sweet quote from hellrazr
#12 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
also what were you launching at?
2002 Gt
Not Slow
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
1992 Lx
11.39@119.24
id see a 13.5 easy
93 GT N/A 302 H/C/I
6.73@101.7--- 10.59@126.06
Unless you inform us of the RWHP or FWHP and vehicle weight or the MPH it's a shot in the dark at best. Gears, exhaust, and hook can sink a three pedal 5.0L deep into the 13's and high 12's are not out of the question.
N/A 302 Pushrod Power ![]() |
i launch at about 3000rpm. my trap speed is 93mph. 330' 6.54. its a daily driver so obvously no slicks. it going to start raining out here in cali not too long from now. and the tires are good all season. thanks alot for the help. launching at the track and the street are alot different. but my shifts are solid.
#17 | |
Holy Dick Castle!
here is my 14.9 run
60' 2.284 330 6.261 1/8 9.611 mph 73.13 1000 12.502 1/4 14.931 mph 92.86 that was my first time to the track I have an AOD also(info that I could have used before I ran) do not drive in the water box with street tires because water will get traped in the grooves and you will slip eaiser. If you do a burn out only do a dry small one to clean the tires off. and let some air out of the tires.
![]() Last edited by dr.gonzo!; September 28th, 2008 at 05:47 AM. |
my car was very similar to that when it was stock too.
#19 | |
Holy Dick Castle!
lol thats what sucks I bought it with 3.73 gears a valve body shift kit and headers/h pipe. I guess thats how much work a vert has to do to make up the weight diff lol. I have added control arms and lowerd it so I might take it back to the track a little wiser this time.
#20 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/90245-problems-track.html
| problems at the track | This thread | Refback | September 27th, 2008 10:07 PM | |
Threads Similar to: problems at the track
| going to the track soon!! | 91cobra5.0 | 5.0 Mustangs | 20 | June 11th, 2008 10:31 PM |
| Going To The Track... | oh2swapped | 99-04 | 3 | April 10th, 2008 03:50 PM |
| S197 Gearbox problems only at the track?? | Lazyracer | 2005 - 2010 | 20 | March 17th, 2008 10:50 AM |
| Went To Track | jivepepper | 99-04 | 2 | November 17th, 2007 07:12 PM |
| FIRST TIME AT TRACK, NOW TRANNY PROBLEMS. | 5.0FUZ | 5.0 Mustangs | 19 | August 21st, 2007 06:40 PM |
