air / fuel - Page 2
LinkBack (1) Thread Tools
Old October 8th, 2008, 01:44 PM   #21
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by temple30 View Post
at idle it's (15.7) , any gear 2,500 - 3,500 cruising (15.6) surges but if I give it some gas it runs great (13.2), wot it runs the best (11).. I do have a custom tune , the tuner has looked at the problem and says that that is the most fuel he can put without hurting the high rpms... It's just a 306 with f cam , vortexh supercharger making 12 lbs boost (when it is in full boost it feels great but the boost gauge reads 20-22( don't think that's right it runs really well in wot)
You need a new tuner. I have a very similar set up and it runs perfect at any rpm and any throttle position. It also makes 15psi.
How do you know you are making 12psi if the gauge shows 20-22psi?
Old October 8th, 2008, 03:31 PM   #22
1988 GT 306 S Trim
temple30 is on a distinguished road
If you ease your way into it it stops around 12-13 but if you are in say second gear and you just floor it it will go up to 20-22 and it pull super hard. I have 42 lb injecters that should be big enough for my setup right.
By the way how much power did your car do.
Sorry guys I forgot to tell you it has a mr. Freeze kit on it don't know if that is hurting the turner tuned the car without the meth. First then add it to the car and retuned
Old October 10th, 2008, 01:42 PM   #23
1988 GT 306 S Trim
any advice guys come on
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/90587-air-fuel.html
air / fuel This thread Refback September 29th, 2008 12:46 AM
Threads Similar to: air / fuel
Air/Fuel Help! 04mustang232 The Clubhouse 1 June 12th, 2008 01:20 AM
Air Fuel Ratio SoonerStang 2005 - 2010 11 October 31st, 2007 08:10 PM
What should my Air fuel mixture be? demononwheels 5.0 Mustangs 6 August 13th, 2007 12:38 AM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
