air / fuel
LinkBack (1) Thread Tools
Old September 27th, 2008, 08:54 PM   1 links from elsewhere to this Post. Click to view. #1
1988 GT 306 S Trim
temple30 is on a distinguished road
air / fuel
what is the a/f number I'm trying to get or is it different for each motor
Old September 28th, 2008, 09:45 PM   #2
1988 GT 306 S Trim
thanks guys anyway I'm getting around 15.9 around town and 9-10 wot
Old September 28th, 2008, 09:48 PM   #3
Really dont know what your trying to ask?
PeteAndersonRacing.com
Old September 28th, 2008, 10:07 PM   #4
1988 GT 306 S Trim
my car seems to be running rich around town and in wot it runs lean but I'm trying to find out what the best number is 12,13,14,15 I think it should be around 13.5
Old September 28th, 2008, 10:23 PM   #5
fogged306's Avatar
89 GT
If you are referring to your car with the s-trim, 11:1 would be ideal... according to that handy injector chart
Old September 29th, 2008, 12:12 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is it naturally aspirated or does it have a power adder?
Old September 29th, 2008, 12:44 AM   #7
1998 Cobra
13.24@105.66
lol.. 9-10 is rich and 15.9 is lean.. you got it backwards.
usually a boosed car has a safe air fuel ratio between 11.5:1 to 12:1, and a naturally aspirated car likes around 12.4:1 to 13:1 as safe air/fuel ratio.
weeee foooord!
Old September 29th, 2008, 10:58 AM   #8
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Yep, you could probably see more horsepower (and possibly even more reliability) if you leaned it out a little at WOT. If it's not misfiring while cruising, though, the cruising AFR should be good for mileage.
Old October 2nd, 2008, 12:26 AM   #9
1988 GT 306 S Trim
lol that is funny as you can see still learn, ok so the 9.0 is rich and the 15.7 is lean. Just got it back from the dyno/tune it made 462 to the wheels and is still running around15.7 crusing and 9.0 wot. The car wants to kindof die out in 1st gear around 2500-3000 rpms then it gets better shifting into 2 for some reason. I think it may be the cam ..... any ideas
Old October 2nd, 2008, 08:58 AM   #10
Authorized Vendor
9.0 is pig rich, blacken the spark plugs rich. Do you have a wideband AFR gauge on it? Also, does it do this at 2500-3000 RPM in other gears or just in first?
Old October 3rd, 2008, 12:57 AM   #11
1988 GT 306 S Trim
it does it in other gears you just dont fell it as bad as 1st and 2nd(once you are in it all the way it feels real good but if you are just cruise at 3,000 rph in four gear you will fell a surge.
Old October 3rd, 2008, 12:58 AM   #12
1988 GT 306 S Trim
i do have a afr guage on it
Old October 3rd, 2008, 01:02 AM   #13
fogged306's Avatar
89 GT
Is it a wideband though?
Old October 3rd, 2008, 10:36 PM   #14
1988 GT 306 S Trim
really embarrassing what is wide band
Old October 4th, 2008, 02:15 AM   #15
1992 Lx
11.39@119.24
its a diff o2 sensor than the stock ones, hook it up to ur exhause by welding another o2 bung and it tells you the air fuel ratio muchhhhh more accurately than the stock ones
Old October 4th, 2008, 11:32 AM   #16
1988 GT 306 S Trim
yes I do have wide band
Old October 6th, 2008, 11:05 AM   #17
1988 GT 306 S Trim
I wonder if the reason I'm having such a surge is it's not getting enough fuel it's showing around 15.6. It runs ok in first gear till it gets to about 2500 rpm, 2 nd ok till around 2,900 rpms , 3 rd around 3,100 ithink I'm just not getting enough fuel.. Any suggesttions
Old October 6th, 2008, 03:34 PM   #18
Authorized Vendor
If it's showing 15.6 when you're getting on the throttle, yes, you're not getting enough fuel.
Old October 6th, 2008, 03:47 PM   #19
ryans88gt's Avatar
Are you talking about part throttle operation, full throttle operation, or almost no throttle operation.
What is your timing setup like? base timing, tune, timing retard curve?
Old October 8th, 2008, 09:42 AM   #20
1988 GT 306 S Trim
at idle it's (15.7) , any gear 2,500 - 3,500 cruising (15.6) surges but if I give it some gas it runs great (13.2), wot it runs the best (11).. I do have a custom tune , the tuner has looked at the problem and says that that is the most fuel he can put without hurting the high rpms... It's just a 306 with f cam , vortexh supercharger making 12 lbs boost (when it is in full boost it feels great but the boost gauge reads 20-22( don't think that's right it runs really well in wot)
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/90587-air-fuel.html
air / fuel This thread Refback September 29th, 2008 12:46 AM
Threads Similar to: air / fuel
Air/Fuel Help! 04mustang232 The Clubhouse 1 June 12th, 2008 01:20 AM
Air Fuel Ratio SoonerStang 2005 - 2010 11 October 31st, 2007 08:10 PM
What should my Air fuel mixture be? demononwheels 5.0 Mustangs 6 August 13th, 2007 12:38 AM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
