1987 ford mustang gt
well see when shes done
systemax and pics
could someone please give me some insight on how the vacuum lines are run on a systemax intake.
my infinity ![]() all the wires are ran ![]()
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
Lookin good.....just got a halfy.....
What vacuum are you running? Pcv, vacuum tee,brak booster,fpr,canister .....?
PeteAndersonRacing.com |
pvc
95 opalfrost gt
It doesnt really matter how you run them as long as everything that needs vacum gets it.
Front port on the upper intake which doesn't have a brass port on it in your pic above should go to the pcv. The larger of the three ports on the back of the upper should go to the vac tree on the firewall. The two small ports on the back of the upper should go to the vac bundle towards the pas side and the other should go to fuel pressure regulator.. if you have mass air the map/bap sensor doesn't get a vac line to it. If your speed density then you have to have a dedicated vac line for it to the manifold somehow.
1988 lx
9.68@142
the only vaccuume u need to run is one of the small ones in the back need to go to the fuel pressure regulator, one of the big ones in the back need to go to the pcv valve and one of the big ones needs to go to the tree none of the other ones matter unless ur running smog and i believe ac uses a vaccume.
Anything to do with smog has been deleted off the car.
I only run pcv and brake booster....dont really need the others on my car.
Got the stock black air box back in it now
You could probably get away with running a single line from the rear connection to the PCV (if you using that), and the front connection to the stock vac tree on the firewall. Should be plain and simple?
Here is a pic of mine for reference. It is an old pic and looks sloppy so this may be what you DON'T want to do For me, there is a lot of stuff. I still have all emissions, heat controls, canister purge, fmu, ac, boost retard input etc.. It looks like crap but it works. I don't know where that "octopus" connector came from but my stock 5.8 bronco has one similar.
wow that vac line thing is insane looking.. why not purchase a vac block to clean it up a little?
and like I said in post 5 here's how holley suggest doing it and how I did it.
No life....do you live in mexico?
#12 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
where the hell is everything lol.
No a/c, no power steering,battery in the back, and I hid the wires under the fenders
#14 | |
Holy Dick Castle!
how did you do the solenoid?
What do you mean....?
Bolted it up under the fender....
#16 | |
. Although I still have the same amount of vac lines as before, that was an old picture so it looks a LITTLE better now.
Threads Similar to: systemax and pics
| My lunch(pics) plus flood pics | itschristorres8 | The Clubhouse | 12 | August 26th, 2008 03:29 PM |
| systemax and twisted wedge | 1BADSTANG | 5.0 Mustangs | 4 | May 10th, 2008 12:34 AM |
| Tallahassee pics and a few pics of stang. | MustanG_guy17 | The Clubhouse | 3 | February 15th, 2008 11:51 PM |
| Holley Systemax heads | 86gt5liter | 5.0 Mustangs | 3 | December 6th, 2006 04:42 PM |
