Underdrive pulley
looking to pick up an underdrive pulle kit for my 1992 gt havent looked to hard to find one yer was wondering wat are some good sites you guys use for parts also what a grood brand of pulleys would be ?
Summit. March or BBK underdrive pulleys are good. There are alot of other good ones out there too.
srry for the serious masacre in my last post lol. but anyways i was looking at some bbk steel underdrive pulleys, I was going to get there steel kind since they should be built stronger but idk for sure. Aluminum is light and may give me a better take off even if it is a hair of a second what are your guys ideas?
the difference in weight is so minimal i don't think it would make a difference either way. for something as simple as underdrive pulleys, just buy the cheapest ones you can find. mine were made by CAT...never heard of them? me neither, but they were $40 and do the job as well as any
i got my pullies at a UPR table at a swap meet for the NMRA. I dont think they make pullies though, or at least i havent been able to find them if they do. anyway, whatever brand they were, they cost $80.
You can usualy find a cheap set on Ebay
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.85@102mph |
2001 svt cobra
no way (IRS)
I got the BBK steel from CJPONYPARTS.COM($80.00), the only thing I might be aware of was that when I used the alt. pulley it greatly reduced the output of my alt.. So I went back with the stock Alt. pulley :sleep
so if i go with them keep the stock alt pulley ??? or was that just in your case 89 ragtop ?
some people have had problems so they go with a 130 amp alternator....that should keep it charging well. Get one off a taurus or buy it new.
how much off a taurus u think and what year ???
2001 svt cobra
no way (IRS)
Yes in my case it benefited me to reinstall the factory ALT. pulley(lights were going dim at idle). you can see if this is the case with yours
1993 Mustang LX Vert
Just put a set ot BBK on my 93 covert Wednesday, haven't had any problems thus far, and as far as the alt pulley the new BBK was actually slightly bigger than the original but I still put it on anyways.
Well personally I would like to see a test done to see if there is a difference. In theory rotating mass weighs more then stationary mass. For example 1lb weights 1lb, but a 1lb pulley rotating at X speed then it now weighs 1.3 lbs. Not 100% sure on formula. So you would be gaining on loss of weight but how much is the real question. I do say the billet pulleys are better since they would never rust or need painted. And the cost isn’t that big of difference 50 compared to 80….
"90 LX 12.5 @ 114 / $8,500 invested? How much did you spend on that 13.0 Vet?" "Treat your car like you treat women: wash, rub down, pamper, then pound the shifter in every gear, drive it till it gets loose and trade it in for a new model!" |
#14 | |
Yes and no at the same time! The rotating mass (weight) helps you only when launching the car from a slow roll or a complete stop. For example pick up a bucket of water and throw it as far as you can with out spinning it around first. Then using the same amount of water in the same bucket twirl the bucket around and around like a helicopter and then release it. The second throw will travel much further. I had an AWD Eclipse and with the stock fly wheel I could launch the car at 3k RPMs but when I put on an aluminum flywheel I lost the ability to launch the car at 3k, I had to at 5-6k RPMs.
(So you loose little launching ability with lighter pulleys and flywheels but gain lighter weight car and more HP) But with RWD not many are worried about gaining or loosing launching power!
1 pound of rotating mass is equal to 8 lbs of dead weight. However in the case of underdrive pullies the difference is so minimal that you will never notice it.
thats alot of helpful info not really for the get up in go i want it in the long run
do you have gears? you will get up and go with some 4:10s for sure!
"1 pound of rotating mass is equal to 8 lbs of dead weight. However in the case of underdrive pullies the difference is so minimal that you will never notice it. " Are you sure it's not 1.8lbs rotating to 1lbs dead weight? I don't think it's that much of a differance. If a steel pully weighs 5lbs then that would be 40lbs rotating. I think the ratio is 1.8 for ever 1lb, if i'm wrong then please corect me. I'm looking for it online but with no luck.... LOL every100lbs is a .10 in the quarter mile
#20 | |
also its important to point out that, although 100lbs is about a tenth in the quarter, normal street driving is where weight reduction really pays off. consider driving and never shifting later than 2000rpm. at 2000rpm our 5ohs only have about 100hp. at 100hp, weight plays a much larger role in performance. |
Threads Similar to: Underdrive pulley
| Underdrive pulley question | Badasstang281 | 99-04 | 37 | July 18th, 2008 11:48 AM |
| Underdrive pulley questions | hubba076 | 99-04 | 9 | May 17th, 2007 12:13 PM |
| is this a good underdrive pulley? | gooberhead320 | V6 Mustangs | 6 | May 12th, 2007 05:48 PM |
| Underdrive pulley help | Timmano | V6 Mustangs | 23 | March 28th, 2007 11:45 AM |
