351 cleveland
hey guys i am new to this site but have owned my 5.0 for a couple months now, i was wondering i kno u can put the 351 w in ur fox relatively easily but can u put the cleveland in
thanks jim |
has anyone ever tried this swap b4
![]() iTrader: 1 reviews
This is not an instant message, someone will reply you gotta wait alittle, I'm sure someone will reply.
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
i kno i have posted on other accounts
but anyway i was just hoppin someone has done this cause i was told it was very hard |
Yes it can be done and there is at least one guy here that has done it. We shall wait for the Bossman to chime in.
I'm not BOSSMAN but I have a 351w in my foxbody. A Cleveland swap is a little more involved.
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.85@102mph |
My friend and I researched it quite extensively. The cleveland is much wider than a windsor. It is also heavier. The parts for it if you should break something are also alot more expensive. But it would be cool.
A 351 Cleveland is 1/2" wider and 1/4" longer than a 351 Windsor. Clevelands have bulkier heads but the deck height is 9.2 versus 9.5 on a Windsor. The Cleveland in stock form weighs 25lbs more than the windsor.
clevelands are not more expensive if you know what your doing and they will run circles around a windsor also if you know what your doing. The swap is nothing dramatic
#10 | |
#11 | ||
#12 | |
#13 | ||
Im not normal but until the aftermarket came around the windsor was a dog. You wanna run, you ran a cleveland. New guys just get the windsor stuff shoved in there face, which I dont knock, its plentiful, cost effective and no doubt works very well, but it aint no cleveland IMO. I can say this a buddy of mine runs his 3100 lb fox with a 357 cleveland with aussie 2v closed heads and it runs 10.90's all day long. Its a 3500 dollar motor at the end of the day. 3 years of the shit kicked out of it. Im just partial to clevelands, dont mind me. Another one of my members has an old set of dyno don 4v heads worked to the max and they go 375/280
#14 | |
guys believe it or not this is why i wanna do it, i mean i read someone with a huge cam 650 lift and 320 duration with ported cleveland heads on his 351 had well over 550 hp so i kno these heads can flow i was just hopin i could go cleveland and just put a big cam in and be done with it i just was never told how hard it was
and i am determined to find out |
Threads Similar to: 351 cleveland
| has anyone put a Cleveland 351 into an SN95? | dasfonzie | Modular Mustangs | 9 | December 31st, 2009 03:46 AM |
| 351 Windsor or Cleveland | Newtgadget | 5.0 Mustangs | 23 | November 6th, 2007 05:57 PM |
| 1970 351 cleveland | mattsstang | Classic Mustangs | 8 | January 19th, 2007 11:54 PM |
| Cleveland Heads On A 5.0 | 81 Merc. Capri | 5.0 Mustangs | 4 | October 22nd, 2006 07:47 PM |
