98 Cobra
speedometer cable
going to the junkyard today at lunch, is there a way to tell if they arent worn out?
yea if they are not broken or if they are still looking clean like urs did when u first got it. If u didnt look at it then just amke sure the connections on the end arnt breaking. Also make sure that when you turn the transmision that they turn at the dash. Also make sure they are not bent.
98 Cobra
Awsome thanx
98 Cobra
Is there a certain way you have 2 put it into the tranny? It should just slide in right,
2002 Gt
Not Slow
![]() iTrader: 1 reviews
where does it slide in to the tranny?
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
You have to unclamp it first on you tranny. Then screw it in. Make sure not to screw it in to tight or you will break the belt inside. Just be careful with it because they are very fragile.
Threads Similar to: speedometer cable
| Quick speedometer cable question | Matt300ZXT | 5.0 Mustangs | 0 | August 5th, 2008 01:12 PM |
| speedometer is off | 1BADSTANG | 5.0 Mustangs | 9 | June 17th, 2008 11:26 AM |
| Speedometer | Arhilion | 96-98 | 8 | May 23rd, 2007 07:36 AM |
| Speedometer | 88MustangGT | 5.0 Mustangs | 8 | January 3rd, 2007 07:11 AM |
| How To Tell A Bad Speedometer Cable? | 5literJeff | 5.0 Mustangs | 1 | September 5th, 2006 12:30 PM |
