What in the world is wrong here?? - Page 2
Old October 1st, 2008, 01:22 AM   #21
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
Originally Posted by nolife View Post
I had that problem. Before I figured it out, my cats turned into a glob and I had enough fuel in my oil that it looked and flowed like black coffee and it took a few oil changes to get it all out of there. At least my engine is clean now
yeah i had the same problem with a brand new holley AFPR.
it sucked so much fuel into my intake there was a huge puddle in the intake and my car barely ran. it would just die in traffic. it was fun the first time when i didnt notice and lost my power brakes. thats a good eye opener.
Old October 1st, 2008, 09:03 AM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by UL-B-SRY View Post
okay so i've had my stang for about 2 months, i know its a 5.0 and a bit of a gas guzzler...but i've spoken to a few other people who own or have owned mustangs and they say it should be no where near that bad, and i've tested my MPG and stuff right now i'm getting around 10-11 mpg. The car is stock with no mods, and i don't really drive it hard much at all. The check engine light does come on and off, i took it to a ford dealership and paid them 95 bucks to pull the codes, it came back clean. i'm not sure if maybe its a leaky injector, or if O2 sensors would cause the gas mileage, to be off by that much. I have noticed recently that sometimes when i start the car first thing in the morning it will sometimes almost die, or stall out completely. So i'm not sure if it could be a leaky injector causing this or anything. You can smell the car is running very rich. Haven't had time to put it on a wide band or anything to check the actual ratio. Any clue what could be causing this? I hope someone can give me some advice or things to check out, because i've looked over my bank statement today, and i've put literally over 1400 in gas in the car in 2 months.
Something is definitely wrong. I built a 91 GT with a 302 and a 5 speed that ran 11.50s and did 25mpg on the highway. My 92 GT with a blower and over 500rwhp gets 20mpg on the highway with a bad tune. My 90 LX with a 742hp ran 9.30s and got 14mpg on the highway. I had a damn near stock 88 GT that had 3.55 gears, K&N air filter, fiberglass hood and was lowered and that did 27+mpg on the highway.
Old October 1st, 2008, 11:17 AM   #23
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
okay so i did get the codes pulled from the EEC, the two i got were
KOEO - 111 no faults detected during KOEO
Memory Code
172- HO2S (sensor System Lean Bank 1)
173- HO2S (sensor System Rich Bank 1)
so its obiviously the o2 sensors messed up...but i mean would o2 sensors cause it to be that bad???
Old October 1st, 2008, 11:25 AM   #24
1992 Lx
11.39@119.24
yes they could, my 94 stang i had had bad o2 sensors when i got it and that shit was terrible and the car was very slow
Old October 1st, 2008, 11:27 AM   #25
Traidmarx's Avatar
1995 Mustang GT
so in your opinion could that be why the car runs like ass half the time and feels like its missing at random sometimes?? I just wouldn't have thought o2 sensors would've caused so much problems...but guess so.
Old October 1st, 2008, 12:05 PM   #26
fogged306's Avatar
89 GT
You may have more than one issue, I would replace the o2 and see where you end up. It may cure your problems entirely it may not, but it won't hurt.
Old October 1st, 2008, 12:18 PM   #27
Traidmarx's Avatar
1995 Mustang GT
got ya i'm gonna replace them this weekend....and i'm also changing the oil...another side question but is royal purple really as good as they say??
Old October 1st, 2008, 01:10 PM   #28
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
hey Tim I have some extra newer injectors , you might have a bad injector or something going on , pull the plugs and see if one is more black or white than the rest of them , Royal Purple is ok , but Id just run some castrol GTX 10w30
Old October 1st, 2008, 01:13 PM   #29
Memory Code
and for these codes , you should never see both sides reading opposite of each other , might be lower intake gasket only leaking air in on one side , and its richening up trying to correct and making the other bank rich , while still reading lean on the other side
Old October 1st, 2008, 02:44 PM   #30
nolife's Avatar
91GT, 88GT, 02GT
Start now with the PB Blaster or WD40. They may come off with no problem and they may not. The last ones I changed chewed up the threads on the pipe bung.
In my opinion (and we all have them), not worth the money in anything but an all out track car where every fraction of a HP could make a diffference.
Old October 1st, 2008, 04:58 PM   #31
cisco191roush's Avatar
1991 hatchback Gt
cisco191roush is on a distinguished road
I had the same problem a few weeks ago, usually my car gets between 20-22 miles a gallon, then start given me about 9-11 miles/g and was runing rich on gas, when cold will die, I was thinking of bad O2 sensors might be given me the problem, I replace them with a spare set I have, but that didn't fix the problem. I found a vacum house, the one tha goes from the canister to the upper intake was crack i replace it with a new one, now my car is runing great with no problems whatsoever.
Old October 1st, 2008, 05:10 PM   #32
Traidmarx's Avatar
1995 Mustang GT
i'll check that thanks....where is it located on the motor??? (sorry not familiar with 5.0's i've always worked on 4.6's)
Old October 1st, 2008, 05:20 PM   #33
1991 hatchback Gt
tha canister is locate it under the air box, and that vacum house runs from the canister goes under the alternator and finally passes behind the distributor, connects in the front of your upper intake, between the lower and upper intake, hope this solves your problem, it was a easy fix for me under $5 bucks
Old October 1st, 2008, 05:24 PM   #34
Traidmarx's Avatar
1995 Mustang GT
i actually think that hose is missing from my car all together my friend was looking at the motor and had mentioned that.
Old October 1st, 2008, 05:29 PM   #35
1991 hatchback Gt
so that might be the problem, cause the canister controls in grand part emmisions
Old October 1st, 2008, 05:30 PM   #36
Traidmarx's Avatar
1995 Mustang GT
i'll look again i go to lunch i'm at work right now but i'll look here in a few and post an answer
Old October 1st, 2008, 05:33 PM   #37
1991 hatchback Gt
Ok, let me know if that fix it.
Old October 1st, 2008, 11:06 PM   #38
Traidmarx's Avatar
1995 Mustang GT
i was looking and couldn't find it....anyone have any pictures of where i can look???
Old October 2nd, 2008, 01:46 PM   #39
all your emissions crap is up in the passenger side inner fenderwell , above the tire , purge solenoids and crap
Old October 3rd, 2008, 12:13 PM   #40
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Royal Purple is probably the most horsepower producing oil......if there is such a thing. I know people that have seen 8-10hp out of it but on a daily driven car I think it is not worth the money. A good synthetic will help keep the engine healthy but you don't need to spend a fortune on Royal Purple.
Threads Similar to: What in the world is wrong here??
What is wrong with this world..... Casper98GT The Clubhouse 14 November 4th, 2010 08:23 PM
what in the world is wrong with that guys thread that goes by the title of "what... Onemanzu The Clubhouse 18 April 3rd, 2008 03:28 PM
What in the world is wrong with SVT forums? dirtybird91 The Clubhouse 0 April 3rd, 2008 10:01 AM
what in the world mustang1072 The Clubhouse 13 March 29th, 2007 12:48 PM
The Only One In The World Stock Multimedia 6 November 16th, 2006 08:12 PM
