2002 Gt
Not Slow
![]() iTrader: 1 reviews
Welding Diffs...
I am about to weld my spider as a inexpensive way to fixing my trac loc... Any objections before i begin.?..
im looking for some opinions on this
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
1992 Lx
11.39@119.24
dont give it gas going around corners unless u wana learn to drift
2002 Gt
Not Slow
yea, that i know most def ,.. but other than that is there anything i would need to worry about. Someone told me that it would reduce the life of my axles... is this apparent?
98 Cobra
i dont know about the axles but id the welds brake you could have a lot of metal shavings in ur rear end. engind result having to replace races, bearings and probly a few seals, but i have heard of people doing it so
12.8@103... stock motor
11.8@113...150 shot
yes if you have stock axles i'd worry about them twisting or breaking.
street driving a locked differential causes a lot of wear and tear. |
i had a welded in my nissan 240... don't do it if your daily your car.. it sucks.
drag car/drift w/e, do it
weeee foooord!
if its street driven much, you will wear rear tires even more than you do now and maybe a little more than normal wear on front mainly cupping the edges do to the more effort to get the car to turn, spend a few bucks and put new clutch packs in it cause once you weld it the whole unit is worthless
Do not weld your spider gears. That is what people do with demolition derby cars, not street or race cars. All you will accomplish is destroying a perfectly good traction lock carrier and eventually a broken axle(s) because now your tires are going to turn at the same speed when you turn corners. Do it right and put some clutch packs in it or leave it as it is. Do not weld spider gears.
1989 Mustang LX
10.98@126.7 NA
Bad idea and it will end up costing you more. Do it right.
Never fast enough.
2002 Gt
Not Slow
hmmm,. ok. where can i find the absolute cheapest rebuild kit. Shortly i will have a cobra rear end,.. so i am trying to do this as cheap as possible for now
2002 Gt
Not Slow
i probably should have mentioned this earlier,... does this change any opinions?
If you are getting a different rear end soon then why even waste the time rebuilding this one?
2002 Gt
Not Slow
well, it wont be for a few months until i get the other rear end,. so until then i'd like to have both wheels for power while i screw around. I cant use really any of 1st because one wheel will just start roasting
1989 Mustang LX
10.98@126.7 NA
Ratech from Summit
Never fast enough.
98 Cobra
is it a whole rear end ready to drop under the car or is it going to need parts out of the old one? if not then fuck it, honestly if ur getting a perfectly good rear end ready to drop under it then oh well either just leave it be or just weld them bastards
dont weld them its not worth it, check out the how to rebuild trac lock forum it list a kit their with all you need
2002 Gt
Not Slow
yea i know all about the rebuild,.. i was just shying away from spending 50 bux on the rebuild kit
2002 Gt
Not Slow
1989 Mustang LX
10.98@126.7 NA
Ratech 1808 - Ratech Clutch Pack Kits - summitracing.com or Ford Racing M-4700-B - Ford Racing Traction-Lok Rebuild Kits - summitracing.com the ratech used to be cheaper, now I see that the FMS is plus it comes with friction modifier
Never fast enough.
That what i did with my derby car.....
PeteAndersonRacing.com |
Threads Similar to: Welding Diffs...
| This guy needs a little welding help. | 06VistaBlueGT | Videos | 18 | October 25th, 2008 05:06 PM |
| welding exhuast | dr.gonzo! | 5.0 Mustangs | 5 | March 22nd, 2008 12:25 AM |
| welding | terribleonexx88 | 5.0 Mustangs | 0 | September 9th, 2007 06:17 PM |
| welding | terribleonexx88 | Northeast | 0 | September 9th, 2007 06:15 PM |
| Welding | Horseshoeing | The Clubhouse | 10 | May 21st, 2007 06:08 AM |
