1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Any Tips on cleaning up my motor??
the motor is flithy below are some pics, i've tried different engine cleaners...tried scrubbing it came a little clean but still very dirty any other suggestions??
![]() ![]() the car is a little dirty from all the rain...but still fairly clean on the outside to be a 95 and yes i need rims ASAP lol
looks like you had a coolant hose blow up all over the engine bay...lol
take it to a car wash, leave the engine running and use the pressure washer on that bad boy.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#3 | |
94 GT
and i suggest using a couple cans of carb and choke cleaner to clean off oil on the bottom of the engine
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
With the engine running I useally soak the hell out of it with armoral and then drive it around for 15 to 20 minutes.. then pop the hood and she's clean as can be
1992 Lx
11.39@119.24
this is what i was gona say, spray thie shit out of ur engine with simple green or somethin then drive to the car wash place so all that crap gets hot and pressure wash the shit outa it, just avoid spraying ur dizzy and cover ur dam fuses first
89 GT
Advance Auto Purple Power and a pressure washer will do wonders , then I would take off the pulleys and paint them black , except for the PS since its pressed on , mask it off and spray it black with the belt off of course , and then ditch the smog pump and get a 895K6 belt from a parts store to bypass it and gotta love that 2 mile Autolite coil wire
88 Gt
Not Slow
kragens has a solvent that works really well for cleaning parts,.. soak it with that and pressure wash it off
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
& clean those poor rims.. That engine bay looks like that car was a flood victom.. Not trying to be mean. Just saying...
and if you dont clean that thing normally hopefully you dont have some gunk keeping gaskets good i cleaned the shit out of mine a while ago and discovered two pretty big had gasket leaks lol
90 lx hatch |
I agree, it needs alot of work. I would use purple power cleaner or simple green and let it sit for about 10 min then pressure was it while the motor is running.
1990 LX hatch
most road grime and engine dirt that is not greased based will come off with CLR, you can get it at wallgreens. Next use carb or brake parts cleaner for the grease. then finish it off with a can of that overall engine cleaner, that you heso off.
1989 Mustang LX
10.98@126.7 NA
Be careful with brake and carb cleaner. It will f--k up paint faster that you can spray it on. Some spray on bathroom cleaners will take the coolant rust stains off, here again, be careful with painted surfaces. Get rid of that dime store upper rad hose and get the right one. SN 95 cars have coolant / suspended air issues to begin with. The upper hose needs to be as low and close to the upper part of the radiator as it can get.
Never fast enough.
#16 | |
1995 Mustang GT
ya know i was sorta thinking the same thing....but the title is clean. Never ran a carfax on it. But the guy had all the paper work on the motor, that shows it was rebuilt about 42K miles ago. He said the reason for the motor looking so dirty was that the radiator busted, and the car sat for 2 months after that...and thats why it rusted...but who knows. All in all the interior seems to be clean, with the exception of the seats being a lilttle worn but the car is 13 years old. But i got a decent looking SN95 with a motor with 42K miles on it, and a new clutch for less than 3000 so i not a horrible deal i don't guess. |
Threads Similar to: Any Tips on cleaning up my motor??
| Tips on Cleaning Wheels | rsk0528 | 99-04 | 24 | March 7th, 2008 09:14 PM |
| How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? | Jonathan | General Tech | 3 | January 2nd, 2008 10:34 PM |
| Rim type & cleaning tips | recklesstim | Visual | 5 | May 7th, 2007 12:47 PM |
| Cleaning motor? | MustanG_guy17 | V6 Mustangs | 2 | April 5th, 2007 07:53 PM |
| Cleaning Engine area tips?? | jEEd | Modular Mustangs | 2 | January 16th, 2007 03:46 PM |
