Getting ready to tear apart my car, any advice?
LinkBack (1) Thread Tools
Old October 2nd, 2008, 10:32 AM   1 links from elsewhere to this Post. Click to view. #1
90 Mustang GT Convertible
INSTALLER020 is on a distinguished road
Send a message via AIM to INSTALLER020
Talking
I am getting ready to put the following upgrades on my Mustang.
1. GT40P heads, just got them resurfaced, magnafluxed and had a valve job done.
2. 97 Explorer Intake Manifold and 65mm Throttle body
3. Ford E303 Cam
4. Cobra 70MM 19lb tuned Mass air
5. FR 3.73 gears, I am having shop do this.
I have purchased the entire FelPro gasket kit, new head bolts, timing chain gasket, thermostat, K&N filter, oil filter, oil, brake cleaner, anti-freeze and spark plugs. Is there anything else I should have on hand before we get into this job?
Thanks,
Matt
1990 GT Convertible
Soon to have GT40P Heads, GT40 Intake, 65MM TB, 70MM Mass Air, E303 Cam and 3.73's.
Old October 2nd, 2008, 11:06 AM   #2
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
make sure you bought the plugs for an exploder the e7 heads dont use the same plugs as the p heads
Old October 2nd, 2008, 01:19 PM   #3
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
you gonna need special headers for those p heads...
www.hsvracing.com
Old October 2nd, 2008, 01:31 PM   #4
I have a tip i used...Dont completely disconnect the fuel rails...Just move them from one side to another as you work on the opposite side...
Seriously though, good luck! I did an almost identical swap two summers ago....I think you'll be satisfied with it (that is until you get more money and want to go faster!)
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old October 2nd, 2008, 01:35 PM   #5
Hunt_chevs's Avatar
2002 Gt
Not Slow
+1,. they were so hard to disconnect when i was do my rebuild i was forced to move them to aside
Old October 2nd, 2008, 02:15 PM   #6
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
there is a special tool to disconnect those fuel lines, makes it really easy.
but i agree, just move them aside
Old October 2nd, 2008, 02:46 PM   #7
Stock headers won't work.
I thought I could get some 90 degree spark plug wires and would be ok.
Matt
1990 GT Convertible
Old October 2nd, 2008, 03:26 PM   #8
Smirnoff's Avatar
1982 GT t-top
i just put p heads on my car and used the stock manifolds. i had to heat up the number 6 and 8 tubes and beat them in a bit to clear the plugs and then put some 90degree boots on those two...but all the other plugs fit fine
Old October 2nd, 2008, 03:47 PM   #9
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
that sounds like a hack job
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old October 2nd, 2008, 03:54 PM   #10
Smirnoff's Avatar
1982 GT t-top
the dents wont hurt the stock manifolds they're dented so much from the factory it didnt bother me until i get my lt's
Old October 2nd, 2008, 04:43 PM   #11
Inexpensive headers.
OK, I want a budget job, not a hack job. What headers should I be looking for used/budget new for my car.
Thanks,
Matt
1990 GT Convertible
Old October 2nd, 2008, 05:19 PM   #12
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Advice - take pictures and write things down if you're not sure you'll remember them.
FRPP Shorty headers work with the P heads.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old October 2nd, 2008, 05:55 PM   #13
90 dergree boots should work for you...
Word of advice ......lose the E CAM!!!!!!!!!
You will be disapointed.....
PeteAndersonRacing.com
Old October 3rd, 2008, 10:15 PM   #14
These are my Headers!!
I checked and it turns out I have aftermarket headers on my Mustang. Will these work with GT40P heads if I use 90 degree spark plug wires.
86-93 HEADERS, EQUAL LENGTH, 5.0, 1 1/2" MUSTANG
Thanks,
Matt
1990 GT Convertible
Old October 4th, 2008, 02:16 AM   #15
1992 Lx
11.39@119.24
i doubt you can even get those on with the spark plug angle of the p's much less put some plug wires, but try it and let us know
Old October 6th, 2008, 03:02 PM   #16
I will let you know.
I will try it out and let you know if it works or not!!
Thanks,
Matt
1990 GT Convertible
Old October 14th, 2008, 12:23 AM   #17
orcusomega's Avatar
orcusomega is on a distinguished road
I am in the middle of almost the exact same swap - I have a bunch of pics up on my site - Bob’s Slice of the Internet - not an in-depth, step-by-step thing, but i am doing almost the exact same thing. GT40 heads, explorer intake, Trickflow stage 1 cam, 24# injectors, BBK fuel pressure regulator, Walbro 255 lph pump, BBK shorty headers, the works.
Here's a pic of the current state of affairs:
Lemme know if you have any questions, I might be able to help.
1989 GT Convertible "Suicide Sally"
Basket Case bought on 9/6/2008 - BIG plans (small budget LOL)
Project Site: http://www.orcusomega.com
Old October 14th, 2008, 05:20 AM   #18
e3sean's Avatar
1988 lx
9.68@142
i disagree with the whole dont disconnect the fuel rail thing they are very easy to get off there is a tool thats cost like 4 dollars at checker that is one of the most handy tools to have they look like this http://www.drivewerks.com/catalog/im...361-detail.jpg
there are different types but these are the cheapest and easy to use and they are needed on almost every car somewhere they are used on AC,tranny lines,collant lines,fuel lines. just go get them..
<font size=4><b>MILITARY CREW
Old October 15th, 2008, 09:28 AM   #19
Gaskets?
Will the gaskets that come in the Felpro kit work with the 96 Explorer intake I have purchased?
Will they work with the GT40P heads?
Thanks,
Matt
1990 GT Convertible
Old October 15th, 2008, 01:29 PM   #20
87 Mustang GT T-top
The Novice is on a distinguished road
I agree, i have one and i want to take it out and go bigger this winter. Its is obviously up to you but that is just my opinion. If you are looking for better HP gains, lose the E-cam, Z-cam perhaps? But i would go Trick Flow Stage 1 or Stage 2 cam.
Just remember you'll be stuck with whatever ya get. But as along as your happy, thats really all that matters.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/91189-getting-ready-tear-apart-my-car-any-advice.html
Getting ready to tear apart my car, any advice? This thread Refback October 5th, 2008 06:38 AM
Threads Similar to: Getting ready to tear apart my car, any advice?
Getting my car ready for the strip ztweny8 5.0 Mustangs 3 September 1st, 2008 02:12 PM
Car is ready for track bob 5.0 Mustangs 10 August 11th, 2008 07:40 PM
Car Help/advice Needed sn94 5.0 Mustangs 5 June 25th, 2008 03:21 AM
Need some advice about my car. 88stangGT 5.0 Mustangs 10 February 15th, 2008 09:03 PM
Sitting car, ready to get moving! The Novice 5.0 Mustangs 1 July 25th, 2007 09:28 AM
