1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
So I made a BIG MISTAKE,new motor???
okay so i was doing some maintence this morning, noticed that the filter was full of thick black gunk. So i used the K&N recharge thing on it....well not realizing it was gonna take so long to dry out, it had dried for about an hour and a half, and i had to be at work. So it felt dry so i threw it in the car and headed to work. Started up fine seemed to run okay until i started up the road, went into 2nd gear and it sorta bogged down. Motor didn't die or anything but hesitated so i gave it a lil more gas and it slowly chugged through the rpms. So i pulled over cut the car off started it again, and it started fine, idle was fine. So i held the rpms at 2500 and it never sputtered or anything, so i reved it a few times to about 3500-4000 and about the 4th time i heard a lil pop almost like a small backfire, in the exhaust. Pulled back out and it ran fine...i stomped it again in first and it pulled fine, hit 2nd and it ran fine. Came to a stop light pulled off normal and just rolled into the throttle, this time it went slowly through the rpms again. so i shifted into 2nd gave it some gas expecting the same thing and the car jumped foward and took off...so obiviously i sucked a lil water off the filter up, but nothing major it wasn't dripping...do you think the motor will be fine??? will the water eventually burn up?
![]() iTrader: 1 reviews
if more water went in you could have experienced hydro-lock and would need a new engine
but your fine since its running now....
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
and i doubt theres any water left
The Hammer
Millenium Falcon
1995 Mustang GT
it's still bogging a little bit. at random
rags...this week ive proved you wrong and taught you a couple things too so dont start
seafoam that bicth
maybe...im not sure if you should or not honeslty so wati till somebody will more experience gets in here
1992 Lx
11.39@119.24
if u think its that much water in it (which i highly doubt) take ur spark plugs out and turn the car over till you feel content its all out
1995 Mustang GT
got ya...i dunno doesn't seem to be a problem, other than sorta bogging a lil bit but i think that'll work itself out....i'm at work now so i'll let it sit a few hours and see how it runs when i go to lunch
should be fine , just let it dry out good and then take it back off and get some QD electronic cleaner from advance or autozone and spray off the filaments in the mass air meter , it might have gotten some oil on it , and if it did it will make it run lean
#11 | |
The Hammer
Millenium Falcon
it's not like u explained how something worked, u gave me a number. I can memorize things too. And face it, he Demellow'd himself. His car was sputtering and he admits to giving it more gas trying to see what was wrong. Haven't we established when car feels like it's broken don't go faster to make problem go away? so again, i stand by my original post with pride
prob got some junk on the maf. Water is heavier than air... maf will send lots of voltage, rich running hence the bogging.
weeee foooord!
Billy Weston
+1 the air filter can't hold enough water to hydrolock the motor. Probably just got some water/oil on the MAF.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
Try taking some saline solution ( contacts stuff ) and clean off your MAF. Sometimes the oils from the filter got on the sensor and screw with stuff...
( or +1 to the people who were typing the same time as me... But saline solution works like a charm for cleaner the suckers up )
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
#15 | |
That will do it. I kept thinking it was a carb'd engine. Check that...you have to suck in alot of water to do permanent damage. Some shops that "steam clean" engines use more water safely than what you may have sucked in. Your filter would have to be soaked and damn near in standing water for it to have killed the motor. |
seafoam FTMFW!!!
Nike Fast
seafoam is some good shit, but wont help him out here... Im telling you Saline on the MAF.
I didn't know sea foam remove water, I though it remove carbon build up and gooey stuff in your motor?
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
MM's Resident Ricer
2006 Scion tC
13.001@113
clean you MAF before it gets ruined K&N pil will foul one fast, and if you were pulling water off the filter you were pulling wet oil off as well
Clean the filter again. Wash out the filter and let it dry in the sun for atleast an hour and a half. Then oil it and let it sit for atleast 2 hours.
Go get some MAF cleaner from the auto parts and clean the maf. If it is gunked enough you should get a qtip and apply LIGHTLY to the element to make sure. |
Threads Similar to: So I made a BIG MISTAKE,new motor???
| Big mistake | Bevgt108 | 99-04 | 6 | May 13th, 2008 01:46 PM |
| Looking ahead rebuild motor and tran, how much where which one how big? | 1911A1 | 5.0 Mustangs | 5 | February 2nd, 2008 03:16 PM |
| i made the mistake of letting my dad drive my car lol | BWAL | The Clubhouse | 30 | October 4th, 2007 10:08 PM |
| Whats the dumbest car maintenance mistake you have made ? | Fryrice | The Clubhouse | 35 | August 31st, 2007 01:13 AM |
| mistake on the site | Bill | Feedback Forum | 2 | March 27th, 2006 08:47 PM |
