Door gap question..
Old October 2nd, 2008, 06:18 PM   #1
TheBrat's Avatar
91 Mustang LX Fastback
We shall see when she gets done..
TheBrat is on a distinguished road
Door gap question..
Alright, so heres the thing..
I dont ever remember the gap being this tight. The door gap up top is "proper". It dosent have any rubbing issues. But right around where the trim is, and down, the door is rubbing with the fender all of a sudden. And quite bad.
I dont get it, any help?
Brett!
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts
1991 LX. 2.3T in the works.
1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown
1969 Impala. Needs a resto.
Im Canadian, Eh!
Old October 2nd, 2008, 06:22 PM   #2
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
is the fender lining up with your hood and/or bumper ok? You could loosen up your fender and tighten it back up when it's not rubbing with your door as long as everything still lines up to your liking. My buddy had the same issue with his jetta. We took the tire off, the inside plastic in his wheel wall, re-adjusted the fender and everything was perfect after.
Old October 2nd, 2008, 07:07 PM   #3
TheBrat's Avatar
Ya, I dont see any issues with my hood or my bumper.
But heres the thing, like, my car is a roller right now. The most it sees is when I push it around. Unless just pushing on the fenders to move it was enough to move it?
Also, does it make sence that only the bottom of the doors are rubbing?
Brett!
Im Canadian, Eh!
Old October 2nd, 2008, 07:20 PM   #4
89lx,93lx & 88gt
old gray fox is on a distinguished road
have you jacked it up lately ? like on the rocker panel instead of the frame rail.
Old October 2nd, 2008, 07:58 PM   #5
fairlane_68 will become famous soon enough
Have you done any bodywork recently? Like subframe connectors?
Old October 2nd, 2008, 08:07 PM   #6
95StangMX's Avatar
95 Mustang GT
yeah didnt you say you did the subframes while the tires were off the ground?
Old October 2nd, 2008, 08:08 PM   #7
95StangMX's Avatar
95 Mustang GT
you didnt think anyone would remember that did you?...lol...thats what you get for bustin my balls about the chrysler/porsche mistake i made....lol....just messing with you bro...but seriously..that could be your problem
Old October 3rd, 2008, 01:44 AM   #8
1992 Lx
11.39@119.24
yeah he said he welded his subframes on while the weight wasnt on the wheels, grind ur welds off ur subframes and put them back on later
Old October 3rd, 2008, 08:30 AM   #9
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
subframe connector install??????? aw shit! That pretty much answers that, get out the grinder!
Never fast enough.
Old October 3rd, 2008, 06:50 PM   #10
TheBrat's Avatar
Ya, I did do connectors, while it was in the air.
But heres the thing. It just started recently doing this guys, I cant just see a car that has no motor in it, and isnt going anywhere and the gap JUST on the BOTTOM falls out of gap.
Im curious if its from pushing the car around and pushing on the fenders..
Brett!
Im Canadian, Eh!
Old October 3rd, 2008, 07:07 PM   #11
Brett!
It happens as the new metal starts to fatigue into the old metal. You took newer, stronger, thicker material and welded it to older, thinner and weaker material. Never do chassis work like this if the car isn't under it's full weight...including having the engine and tranny in place.
Old October 3rd, 2008, 07:13 PM   #12
TheBrat's Avatar
But heres the thing, I was talking to a bud who builds racecars..
And even he said it shouldnt really do anything, since the unibody should be strong enough to hold the car since the hoist was level, and the car sat level on the hoist.
Also, my car was gutted when they were put in. No motor, no trans, no interior. Just a rear end and a body with some tires.
Brett!
Im Canadian, Eh!
Old October 3rd, 2008, 07:35 PM   #13
Take it to a body shop that has a frame machine. Easier said than done, I know, but have them check the alignment. I know your guy said it shouldn't have done anything, but we're talking about a 17-year-old car with I assume alot of mileage on it. If you haven't noticed on this forum, strange things happen as cars get older.
Old October 3rd, 2008, 07:43 PM   #14
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
The unistructure is designed to flex so it's is pre-flexed or slightly arched to begin with. An exagerated example would be a large semi flat bed trailer for hauling steel, unloaded it arches upward in the middle, as weight is added it settles to level. Your unistructure is slightly arched to allow for loading, with it supported on a hoist, it was flexed upward (unloaded). You welded in sub frames and triangulated the unistructure and "froze" it, not allowing it to flex back. Cut out the subframe connectors and it will relax back, put the engine and trans back in, load the suspension and the gap will come back. That's why everyone kinda warned you about what would happen. Easy enough to figure out.
Never fast enough.
Old October 3rd, 2008, 07:46 PM   #15
good example.
Old October 3rd, 2008, 07:58 PM   #16
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
My simple mind requires simple examples, thanks.
Never fast enough.
Old October 3rd, 2008, 08:51 PM   #17
As soon as you mentioned the trailers, I knew exactly what you were talking about. I used to load those things at a steel fabricator I used to work at.
Threads Similar to: Door gap question..
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 12:49 PM
Door Part Question Ticket-Me-Yellow V6 Mustangs 17 April 9th, 2008 10:59 PM
mustang door question dirte V6 Mustangs 1 October 29th, 2007 09:44 AM
Door locks in a foxbody...got a question RIDIN5.0 General Tech 6 June 12th, 2007 07:08 PM
question about fuel door xiiiix V6 Mustangs 1 January 28th, 2007 08:50 PM
