351w fox efi and turbo build tips
Old October 2nd, 2008, 09:11 PM   #1
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
i have a 88 fox that used to be a 4 banger. i took a 85 E-350 van 351w and c6 and put in the stang for a senior project. its a fun car but it needs more.
i want to take the efi off a 351w truck upgrade injectors and add a twin turbo kit. the set up i planed on using is gt-40 heads with some work. i need a good cam idea. i go to wyotech so i have many friend who build motors and have conections to flow benches and many other tools.
the car is a cheap project if your wondering why i dont buy after market efi and head set ups.
any help or ideas would help.
Old October 2nd, 2008, 09:16 PM   #2
1998 Cobra
13.24@105.66
a stock cam would work fine with turbo.. good lsa and small duration is what turbos really like for good vac.
e or f cam would be a cheap upgrade.
as far as efi goes, no idea i have a carb.
ever thought of going big single?
weeee foooord!
Old October 2nd, 2008, 09:19 PM   #3
5.8mustang's Avatar
1988 mustang lx
i thought of going carb but i dont know what style of carb to use ive heard blow through carb but how big
Old October 2nd, 2008, 09:37 PM   #4
5.8mustang's Avatar
1988 mustang lx
like this minus the aluminum heads and + stock efi
Old October 3rd, 2008, 12:27 AM   #5
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
750 blow thur carb
Carburetor Solutions Unlimited is only blow thru carb I would use.
Ford F cam would work nice. Its a good turbo cam due
to higher lobe seperation.
Built my own twin turbo kit using flipped BBK shorties and cheap T3/T4's
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old October 3rd, 2008, 06:27 AM   #6
94' Cobra 351's Avatar
94' Cobra 351 is on a distinguished road
hey r.barn, how much power you putting down? any 1/4 mile times?
Old October 3rd, 2008, 09:17 PM   #7
5.8mustang's Avatar
1988 mustang lx
thanks for the tips and the link any problems you ran into i should plan for r.barn?
Old October 22nd, 2008, 01:24 AM   #8
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
r barn what was your bottom end in that build?
i want to do a similar build with my 78, but its a stock crank with hyper pistons. probably just a single turbo tho, im afraid my bottom end is my weakness tho, is it worth it to do a turbo build and run low boost? (8-9psi)
Old October 22nd, 2008, 04:23 AM   #9
e3sean's Avatar
1988 lx
9.68@142
sexy
<font size=4><b>MILITARY CREW
Old October 22nd, 2008, 12:22 PM   #10
ryans88gt's Avatar
for a point of reference, a 351 with GT40 heads and mild hyd roller cam is going to make about 250 hp (see early lightnings).
Add to that 8-10 PSI from a turbo and you would be lucky to have 400 hp, although you might have 500+ ft lbs of torque.
I would think there are easier ways to achieve those kind of goals more cheaply. If you aren't interested in cheap, then spring for a real set of heads, like the CNC trick flows or AFR 225s.
Threads Similar to: 351w fox efi and turbo build tips
What you guys think about a turbo fox build?? FX4DTUF The Clubhouse 44 August 18th, 2008 12:29 AM
2.3 efi to 351w carb ks_emt 2.3 Mustangs 2 May 29th, 2008 05:55 PM
Turbo Fox V6 Build: Questions/Ideas? 83rustling V6 Mustangs 17 December 6th, 2007 12:21 PM
After Market 351W EFI Intake Manifolds 5.0newbee 5.0 Mustangs 4 April 19th, 2007 10:54 PM
351W Carb To EFI? 5-0stank 5.0 Mustangs 19 November 7th, 2006 02:41 PM
