double check my plan please
Old October 3rd, 2008, 06:52 PM   #1
sniperrider's Avatar
sniperrider is on a distinguished road
Send a message via MSN to sniperrider
im looking to build a 331 stroker and run 5lbs of boost eventually and possibly ten on the weekends. this is what i came to peace with...Stage 3 Motorsports 331 Ford "Street Fighter" Stroker Kit (Blower)
Dart - SBF Iron Eagle Heads but with a 58 cc to bump compression up a tad. please throw responses at me nice or not i gotta know if this is gonna be a okay combo before i start swiping the card
90 lx hatch
Old October 3rd, 2008, 06:53 PM   #2
im going to run this alone for awhile then throw on some 30lb injectors areomotive fuel kit and a paxton starting with 5 pounds of boost
90 lx hatch
Old October 3rd, 2008, 09:09 PM   #3
anyone opinions??
90 lx hatch
Old October 3rd, 2008, 09:24 PM   #4
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
??? dont run a 5.0. Im a 351w trying to put together a turbo kit for cheap. good luck there is alot of searching to find a good combination.
Old October 3rd, 2008, 09:55 PM   #5
not quite the response i was looking for but thanks?
90 lx hatch
Old October 4th, 2008, 02:08 AM   #6
1992 Lx
11.39@119.24
if its gona be built for boost, why try and bump up the compression?
Old October 4th, 2008, 03:26 AM   #7
1987 ford mustang gt
well see when shes done
Why would you want to run 8.1 compression with 5lbs of boost?
I would try to get the compression around 9.1 at least and up the boost to at least 8-9 lbs if not more.
The stroker kit you are looking at is a chp kit and you could probably buy it cheaper from fordstrokers or chp. Also i would try and opt for a diff head but if that is what you are set on, its your choice. I would opt for an alum. head made by trick flow or afr if you have the money.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 4th, 2008, 03:27 AM   #8
Also why a 331 and not a 347?
Old October 4th, 2008, 12:25 PM   #9
okay the kit is set up for 8:1 compression specifically for boost but 5-10 pounds of boost doesnt need compression that low. which is the reason for the 58cc heads to bump the compression up a tad because im not running alot of boost. i opted for iron heads because i what the strength and durablitlity over the aluminum, and dont exactly have the money. and finally 331 instead of 347 because i can only find a few kits with low enough compression to run boost with a 347 plus dont want to deal with the pin and ringland situation on my first engine build.
90 lx hatch
Old October 4th, 2008, 01:21 PM   #10
woody1 is on a distinguished road
STOP, call me before you start blindly swiping because you have some flawed logic
1-877-723-5487
P.S that kit price is silly
Old October 4th, 2008, 02:35 PM   #11
not a big phone guy can ya just explain the flawed part of my logic on here and let others have input too this is the reason i posted this thread is bcause this will be my first time building from ground zero and if i had the knolwedge i would buy all parts seperate to get whats good but i dont know exactly what the best stuff is so im looking for input on a 331 stroker where i can run 10 pounds of boost and be pushing 450 500 hp
90 lx hatch
Old October 4th, 2008, 05:23 PM   #12
fogged306's Avatar
89 GT
Just call him, you will be glad you did. He knows how to put an engine together and will take all the guesswork out of what you are doing.
Old October 4th, 2008, 06:42 PM   #13
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
It's an 800 number. Call him, you'll be glad you did.
Never fast enough.
Old October 5th, 2008, 02:15 AM   #14
k good deal thanks
90 lx hatch
Old October 5th, 2008, 08:32 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Do you already have a good running 302 in your car? You are wasting your money with a stroker kit. You are planning on a blower which by accident will make 500rwhp on a 302. Spend that stroker kit money on a set of good aluminum heads. Run a good blower with about 10 pounds of boost and you will have more power than you know what to do with.
Aluminum heads are plenty durable and will handle anything you throw at them. They also disapate heat faster. If strength and durability was an issue you wouldn't see all of these auto makers switching to aluminum heads and blocks.
The pin in the ring land causes no issues except mental issues. Regardless, a stroker is not what you need if you are running a production 5 liter block.
Old October 8th, 2008, 06:03 PM   #16
now that is helpful !!so as far as intenals.....they are strong enough to to handle more than the block right so leave them? i had a bad pin in the piston acually a couple they were alittle stiff.right now the motor is out and the block just got magna fluxed what is the best way to go to get five hundred horse with a budget of say 4 grand...this is a street car by the way and i want to do all the work myself gotta learn this stuff and doing it is the best.
90 lx hatch
Old October 8th, 2008, 06:31 PM   #17
End Thread!!!!!!
90 lx hatch
Old October 9th, 2008, 11:26 AM   #18
95StangMX's Avatar
95 Mustang GT
that guy that you were afraid to call is woody from ford strokers....He is awesome at what he does and can save you a lot of money and a lot of problems in the long run....and what do yuo mean you want to do it all yourself you were looking at ordering a motor and what puttin it in the car? and the flawed logic is your beliefs of the fking fairy tales about the 347 issues........
Threads Similar to: double check my plan please
Double checking the check list before I buy Cricket 99-04 10 March 19th, 2008 10:18 AM
So, Here's The Plan Danedog311 2.3 Mustangs 26 January 29th, 2008 07:12 PM
New Plan... zinc02GT The Clubhouse 5 January 13th, 2008 01:09 PM
can you quick check my new little plan please YNOT 5.0 Mustangs 27 May 29th, 2007 04:22 PM
My New Plan xx9gt6xx 96-98 10 November 17th, 2006 07:12 PM
