Why do my blinkers have such a delay?
Old October 5th, 2008, 10:20 AM   #1
noyz25 is an unknown quantity at this point
When i hit my blinkers right or left it takes like 2secs. for it to start blinking. And they blink slow 2secs. apart or so like blink---------------------blink, ETC.
What can i do to fix this cuz its annoying switching lanes in the highway cuz i have to wait for the blinkers to make it safe.
Old October 5th, 2008, 12:12 PM   #2
Add blinker fluid to the reservoir
PeteAndersonRacing.com
Old October 5th, 2008, 12:20 PM   #3
fogged306's Avatar
89 GT
Blinker Fluid [BF-01] - $8.99 : KaleCoAuto, Hard to find automotive items!
Had to
Check your voltage when the car is running, should be at 13.8-14.4 while running, if not you possibly have to replace the flasher.
Old October 5th, 2008, 08:23 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
+1 on the voltage.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old October 7th, 2008, 10:52 PM   #5
Changed my flasher and nothing. Still the same. Anymore opinions? Please.
Old October 7th, 2008, 11:25 PM   #6
fogged306's Avatar
89 GT
did you use a multimeter to see what the voltage is at with the car running?
Old October 7th, 2008, 11:33 PM   #7
Where do i put the multimeter?
In the 2 sockets where the flasher prongs go in??
Old October 7th, 2008, 11:58 PM   #8
fogged306's Avatar
89 GT
No, check the car's voltage at the battery. The less voltage a flasher has, the slower it will operate. Usually poor grounds or a weak alternator/battery will cause slow flashing. Check the voltage, if it's good, redo your grounds on the car from the battery to the frame and from the engine to the frame. If that doesn't fix it, you could have a short in the wiring of your blinker system.
Also make sure to check and make sure all your bulbs are good.
Old October 8th, 2008, 12:05 AM   #9
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
www.1fun4rd.blogspot.com
Old October 8th, 2008, 12:08 AM   #10
Hmmmmm ok. The battery is in the rear(previous owner installed). Thank you will check it out.
Old October 8th, 2008, 12:10 AM   #11
1FUN4RD's Avatar
2007 MUSTANG GT
If thats the case then follow the routing of the wires from the battery to the front of the car. They could be rubbed bare some where
Old October 8th, 2008, 01:02 PM   #12
Well i just notice something. I looked at videos on youtube and my needle for the voltage on the cluster never rises above like 2 lines and a half. Gonna check my voltage after work but i am guessing i'm gonna need a new alternator.
Does having a crappy(smaller) battery be bad also?
Old October 8th, 2008, 04:29 PM   #13
BORDEN's Avatar
91 lx convt
14.02@100
BORDEN is on a distinguished road
+1 on getting a new alternator. ive gone threw three before it charges decent.
and yes for the crappy battery question.
Old October 8th, 2008, 04:49 PM   #14
fogged306's Avatar
89 GT
Before anything, check that running voltage.
A battery being physically small doesn't mean a whole lot. If it starts the car fine and it isn't too old, it's probably fine, as long as it has the proper amount of cranking amps for the car. If it seems weak, have it tested.
Also check the voltage with the car off right at the battery and see what it rests at, anything below 11.9 isn't that great, but that could indicate a poor alternator too. Then check the voltage acrost the connection up front where they tied the relocate kit in and a ground, if it is less than at the battery by anything more than about .1v to .2v you have poor connections somewhere.
Threads Similar to: Why do my blinkers have such a delay?
who knows about clitches in blinkers? 707Stang The Clubhouse 0 August 20th, 2008 07:20 PM
Project Delay, Dammit andres0286 99-04 2 April 27th, 2008 07:28 AM
Blinkers Till 5.0 Mustangs 13 February 10th, 2008 09:18 PM
Blinkers not working! 1badpony 99-04 4 April 16th, 2007 10:26 PM
Speedometer delay 98Stang V6 Mustangs 0 September 15th, 2006 06:59 PM
