LinkBack (2) | Thread Tools |
#1
88 Gt
Not Slow
![]() iTrader: 1 reviews
Removing Smog
what is necessary to get this done? just remove them and make sure the hole is plugged in the block?
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
88 Gt
Not Slow
plug air tube piping from converters , remove pump and all hoses etc , plug any vacuum lines off , pipes coming out the back of each head need to be plugged with 5/8s bolts
#4 | |
It's much easier to replace the air pump with the bracket/idler pulley than it is to remove it and leave it as is when you go looking for a belt. My car has no air pump or AC compressor, and getting a replacement belt was a bitch. Keep the belt setup as close to stock as possible...it's just simpler that way. |
1992 Lx
11.39@119.24
i have my smog pump skipped with a belt but still have power steering and ac, belts 84.5 inches long
it really isnt that hard.
we have smog pump off but ac is still connected, and it is an 86 in belt. the holes need to be plugged, and thats pretty much it. |
unbolt it and chunk it!!! mine looked up and burned the belt off... was close to the house so i drove it till it broke... don't recommend driving with no belt... gets hot quick!!!
www.hsvracing.com |
1993 5.ohhhh
12.97 @140mph
I never looked into plugging the holes, but I beleive my vortech mounting bracket plugs them up.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
88 Gt
Not Slow
so i cannot use the bolt that's made for the tubes (which connects to the block) to plug the holes... anyone got a pic of the pump?
#10 | |
CJ Pony Parts - Ford Mustang Parts
I had my ac and smog deleted, my ps moved up in place of the ac but have since went manual steering so now I only have my 3g alt, crank underdrive and waterpump underdrive pullies so my belt's short as hell. remove all the smog junk and plug the smog tube holes in the back of the heads... only thing though if your still running the stock h pipe with all the stock oem cats then there going to over heat and get clogged. Time to invest in an off road h or x or a catted of choice just not the oem. |
#12 | |
88 Gt
Not Slow
I Have a BBK O/R H
1992 Lx
11.39@119.24
end fucking thread
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/91785-removing-smog.html
| Bob’s Slice of the Internet » Blog Archive » The Teardown Begins | This thread | Refback | March 21st, 2009 05:09 AM | |
| Bob’s Slice of the Internet | This thread | Refback | October 18th, 2008 05:48 PM | |
Threads Similar to: Removing Smog
| Removing AC | moke176 | 2005 - 2010 | 16 | December 19th, 2007 04:04 PM |
| Removing non-working AC & Smog | Project_Stang | 5.0 Mustangs | 9 | September 29th, 2007 11:13 PM |
| removing smog pump on 87GT | marks87gt | 5.0 Mustangs | 1 | April 20th, 2007 04:04 PM |
| removing the smog pump | cali 5.0 | 5.0 Mustangs | 1 | April 19th, 2007 06:34 PM |
| Removing Old A/C | CR70fastback | Classic Mustangs | 7 | January 18th, 2007 06:19 PM |
