Problem with new motor
Old December 24th, 2005, 10:20 PM   #1
foxforever's Avatar
foxforever is on a distinguished road
I have a new motor that doesn't seem to be performing at its best. When I gradually push on the gas the engine performs as expected. However, when I try and take off at full throttle the engine just loses all power. Can you help?
Old December 25th, 2005, 12:08 AM   #2
give us some more details.....cam size, fuel system, gearing, etc.....
88 Mustang Coupe
www.rickscarcare.net
Old December 26th, 2005, 11:15 PM   #3
foxforever's Avatar
I have 165cc ARP heads (61cc), 70mm throttle body, 76mm mass air kit, 24lb injectors, Edelbrock RPM II intake, 1.7 roller rockers, comp cam. What numbers do you need off the cam card?
Old December 26th, 2005, 11:17 PM   #4
foxforever's Avatar
I forgot... I have aeromotive fuel lines and adjustable fuel regulator. The fuel pressure is set at 39psi. The fuel pump is stock.
Old December 27th, 2005, 12:09 AM   #5
lift & duration, rpm range.
did you degree the cam or just stick it in?
when you say it "loses all power", does it buck and jerk, fall flat on it's face and then take off, or does it feel like something is holding it back?
88 Mustang Coupe
Old December 27th, 2005, 12:11 AM   #6
foxforever's Avatar
I replied to your question but wasn't sure how to let you know. I'm new to the forum thing.
Old December 27th, 2005, 10:39 PM   #7
Aliate X is on a distinguished road
Send a message via AIM to Aliate X
Make sure the MAF is clean. I had a similar problem with my stock motor, but same exact symtoms. Cleaned the MAF (the wires) and I went from a 16.9@88 to 14.4@95 (bone stock)
Everything + Nitrous
Old December 27th, 2005, 11:29 PM   #8
IcantDo55 is on a distinguished road
Timeing? Advance?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old December 29th, 2005, 12:25 AM   #9
foxforever's Avatar
Here are the cam specs exactly as on the card:
valve adjustment .000 .000
gross valve lift .544 .544
duration @ .006 tappet lift 276 282
valve timing open @.006 int: 28 BTDC 67 ABDC Exh: 75 BBDC 26 ATDC
Specs are for cam installed @108 intake center line
Duration @ .050 224 230
lobe lift .3210 .3210
lobe seperation 112
Old December 29th, 2005, 12:31 AM   #10
foxforever's Avatar
The timing is set @10 degrees because that is what the tech guy told me to set it at when I installed the diablosport chip.
To be more specific about what it does at full throttle, it just feels like something is holding it back. It just boggs down and won't gain any power unless I let off the gas and slowly apply throttle.
Old December 29th, 2005, 08:19 AM   #11
sounds fuel related to me. For a start, I'd ck the fuel pressure.
88 Mustang Coupe
Old April 23rd, 2006, 06:15 PM   #12
gicantor2's Avatar
gicantor2 is on a distinguished road
Send a message via MSN to gicantor2
Its probably your fuel pump. The stock pump only flows at 88lph and going by the mods you listed your going to need more than that. Its probably not flowing enough fuel in the high rpms.
Threads Similar to: Problem with new motor
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
motor problem? gregkelley 5.0 Mustangs 4 March 15th, 2007 08:59 PM
