LinkBack (1) | Thread Tools |
#1
1988 lx
9.68@142
T5 to C4 swap info i learned.
well i am about done with my swap just have to wire up my trans brake and bolt up my exhaust.
everything went fairly smooth a few things i ran into was.. when you buy a shifter make sure it is for the valve body you have (forward or reverse) make sure you get the correct bellhousing for the flexplate you have (157t or 164t) the bigger bell housing is a little easier to find a seperator plate for cause the AOD uses the same plate. there 2 differnt styles of c4 transmissions case fill or pan fill. if u plan to use a trans brake make sure you have the correct converter built with anti ballooning plates. the stock t-5 crossmember and mount will work but will not line up with the c4 but it is an easy fix. on the crosmember there spot welds on the tubes where the bushings are you can cut the welds very easy with a cut off wheel and tap (pound) the crossmember forward to line up where u need to then re spot weld it. when bolting the transmission to the block before you tighten the bell housing all the way put at least one bolt in the converter and flexplate or you wont be able to line the holes up. (trust me i found that out lol) when you adjust the cable it is easier to find neutral on the transmission then put the shifter in the neutral position and adjust it accordingly. i know this isnt very detaild but if you have any questions feel free to ask. this is my first expierence with an automatic and these are the things that i didnt think of when i first started the swap.
Interesting... I'm working on procuring my fox roller, then i'll worry about the 427, and bolting up the C4.
1989 Mustang LX
10.98@126.7 NA
The 157 / 164 tooth flex plate is a good point. 164 seems to be easier all around as far as matching parts. I did the same conversion on a 95 and ended up going with the 164 because of trouble getting the bellhousing and flex plate to match the converter I wanted plus the 28 vs. 50 oz. imbalance issue. (I have a brand new 10" 3000rpm tq converter for a 157 laying here as a result)
Never fast enough.
#4 | |
1988 lx
9.68@142
89 GT
Good info sean, I'm going to have to steal some (or all) of it for my thread. I can give you $2.50, and an envelope, for royalties.
1988 lx
9.68@142
its all yourse my information is free to the world..
1988 lx
9.68@142
i just took it out for the first time...its weird i have to hold the trans break button to go backwards. my car doesnt want to idle at all in park... it does fine in neutral and all the other gears it just doesnt like park.
i am deffenitly gonna have to switch to my 3.73's this is worse then the 5 speed. i tested the transbreak in the checker auto parts parking lot just to see what my stall is... it says 3500 but it sits at 4000 and damn i let go of the button and its gone...
1988 lx
9.68@142
here are a couple of pics of the shifter install
b&m pro magnum shifter ![]() my trans break button location
1988 lx
9.68@142
man my car is dirty i need to clean it in a bad way.
1988 lx
9.68@142
![]() I know thats rare huh.. all it is is a spring that falls off over time its an easy fix if u pul the center off the spring is proly sitting under there all i need to do now is fix my snake light (map light) and ill have a one of a kind car.
87 Mustang GT T-top
Fits like a glove heh. looks nice though whats that bad boy rated up to HP/TQ wise?
When ya taking her to the track? Let us know, btw when are you taking over the speed channel? Sometime mid month? PS- I'm diggin' the Cat on the Tach
#13 | |
1988 lx
9.68@142
![]() ![]() the transmission is rated at 800hp/tq i am taking the car to the track saturday but its gonna be horrible with the 4.10's and sunday i am taking my car to UTI for an open house to demonstrait a car on the dyno so i get to put it on the dyno for free. i am gonna see what it does with and without the n2o
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/92069-t5-c4-swap-info-i-learned.html
| Auto Swap Question - Street Car Forums - auto forum uniting car and race enthusiast everywhere! | This thread | Refback | November 20th, 2008 05:29 PM | |
Threads Similar to: T5 to C4 swap info i learned.
| PI Head Swap Pics / Info | Uncle Humjaba | 96-98 | 1 | April 11th, 2008 02:18 AM |
| motor swap need info | edwardson | V6 Mustangs | 2 | October 11th, 2007 11:11 PM |
| 8 rib pulley swap info | sonicblue | 99-04 | 12 | September 14th, 2007 11:57 AM |
| 5.0 Swap. Help? [Info Only] | Texan_Stud | V6 Mustangs | 30 | March 12th, 2007 11:12 PM |
| 351 swap info | militarygt | 5.0 Mustangs | 0 | August 20th, 2006 08:47 PM |
