oil pressure
Old October 9th, 2008, 07:57 PM   #1
1985 Mustang GT
viperlocc is on a distinguished road
oil pressure
So apparently my engine has an upgraded high-pressure oil pump and ARP shaft. normal driving im hitting between 20 and 40psi when engine is warm. cold it climbs up to 80psi. using 10w-30 mobil1 oil, stock 302 with windsor jr heads and e303 cams.
what should the oil pressure be? i thought higher than 20psi.
Old October 9th, 2008, 09:57 PM   #2
fairlane_68 will become famous soon enough
on pushrod V-8's any oil pressure is good.
If your motor is fairly fresh or young, try using a lighter oil. 5W30 or 5W20 helps alot, frees up a little power, and gives you better fuel economy. As far as checking oil pressure, use a calibrated gauge that plugs into the oil pressure port. Remote gauges can be misleading.
Threads Similar to: oil pressure
no oil pressure Smirnoff 5.0 Mustangs 3 July 24th, 2008 02:52 PM
no oil pressure OneBoredGuy 4V / SVT 10 June 9th, 2008 07:17 PM
oil pressure skid6 5.0 Mustangs 3 August 10th, 2007 11:50 AM
oil pressure oasr87 V6 Mustangs 4 July 16th, 2007 12:40 PM
oil pressure hmotes 5.0 Mustangs 8 January 18th, 2007 09:30 PM
