LinkBack (1) | Thread Tools |
#1
1990, Ford, Mustang LX
Would you like to meet my Little Baby Cobra?
Transmission Question
I have a 1990 LX series Mustang. The problem is this, fluids is leaking from the aft end of the componet. I have replaced the Tailshaft Bushing, Tailshaft Seal and the driveshaft forward yoke; however, fluid is still present on the ground. Driveshaft is balance. Any solutions before I purchase a Heavy Duty T-5?
Michael L. Mosely. The Saint "I AM" the Saint that satan forgot to warn you about! Would you like to meet my Little Baby Cobra! |
Is the driveshaft yoke wore?
87 Mustang GT T-top
How much fluid is on the ground? just a little or a lot?
And i wouldnt go so far as to buy a whole new tranny, can you just rebuild it? |
95 Mustang GT
the "aft" end of the component huh? You must be a boat guy. +1 with the driveshaft yoke. I wouldnt go out and just purchase a new tranny before you find out whats wrong with your car now. and if you are dead set on a new one you should talk to e3sean he just switched his out for a c4 and might want to sell it
![]() People should think about boarding up their glass house before starting a rock fight! |
Yes the Forward driveshaft yoke was replace (the old yoke was worn), static leak measuring maybe less than a shot glass. I replaced the tailshaft brushing once and the tailshaft seal twice. Did not see a crack anywhere, I will be placing the car on stands to inspect again. I would say that it is more of a xmsn case problem. I worked helicopter in the Army (MH 530's, OH 58A/C, CH 54 Skycranes, etc.), currently modifying KC135 air refueler. Thank's for your inputs, I am very greatful!
may be leaking from somewhere else on the transmission (like shifter) and just working its way down to the back of the trans.
Otherwise, it is a crack.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
I'll look into that ryans88gt.
1989 LX coupe 5.0L
check around the speedo gear
After checking, I've found fluid seeping from the tailshaft seal at the 5:30 position. I wiped, waited and a drip within one minute. Thanks!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/92432-transmission-question.html
| Transmission Question | This thread | Refback | October 11th, 2008 11:45 PM | |
Threads Similar to: Transmission Question
| Another transmission question | ByPopularDemand | V6 Mustangs | 12 | June 19th, 2007 10:06 PM |
| Transmission question | ByPopularDemand | V6 Mustangs | 16 | June 13th, 2007 03:22 PM |
| Transmission Question | mustangrebuilder | Classic Mustangs | 3 | October 25th, 2006 01:27 PM |
| transmission question | mustangrebuilder | Classic Mustangs | 2 | October 23rd, 2006 12:57 AM |
| Transmission Question | theodoor24 | Classic Mustangs | 8 | October 6th, 2006 12:50 AM |
