Discussing dump my exhuast in the 5.0 Mustangs Forum. i like the way my dumps sound....not too loud....but i still have the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
1990 Mustang GT
9.39@76.09----1/8th mile
i like the way my dumps sound....not too loud....but i still have the cats also
![]() stang=40's dumped,pro 5.0 short throw, king cobra clutch, adj. clutch cable and firewall adjuster...pretty much stock 2001 tacoma=magnaflow, K&N cai, tb spacer, 2.5" susp. lift, 32x11.50s, electric fan, few dress up items |
#22 |
1990 "BLOWN" Mustang GT
Single Digit Racing
Between my blower, my fuel pump .. it really doesn't matter if I had tails or dumps. I currently have tails, but I seem to made more power on the DYNO w/dumps. I can tolerate the smell, I used to run 110 so It didn't bother me... the heat, it's the same amount of heat, its all in ur head. Dumps FTW.
![]() 1990 Mustang GT Rich Groh 342ci (We build 'em BIG!) Vortech V-1 S-Trim, with a C-4 ....How fast can it BE? Just fast enough to hold NY & TX on LOCKDOWN! KOTS! BIG Thanks to..... www.rgrengines.com www.kurganmotorsports.com www.artcarr.com |
#23 |
1998 Cobra
13.24@105.66
if your going to dump your exhaust, dump it near the rear axle, not right under the drivers seat like most do. I'm a firm believer that a freeflowing full exhaust will move the power band lower in the rpm without sacfricing peak hp.
Dumps sound cool and are ok for a weekend car, but if you drive it more than 50 miles a week, it's annoying and obnoxious.
98 Cobra - Laser Red/Black - Bolt ons DD '89 Notch - 4cyl car - 2.3T or built 302.. hmm |
#24 | |
Single Digit Racing
#25 |
oh my motor is carb so does that mean i should have straight pipes?
#26 |
1988 Mustang
#27 |
88 Gt
Not Slow
no its makes no difference whether your carbed or not
Stock heads w/ dual angle valve job, chevy valves, K&N intake, bbk equals, bbk o/r H, 2 chamber flows, 373's, pro 5.0, sportline drop http://www.youtube.com/watch?v=biiR0-7pw10 |
#28 |
88 Gt
Not Slow
str8 pipes = zero back pressure
#29 |
MEMBER #334
i heared you lose some torque without tail pipes but i always go with dumps. always
#30 | |
88 Gt
Not Slow
#31 | |
89 GT
What you want is exhaust scavenging, what it does is essentially create a vaccum in which the exhaust gasses travelling out of one cylinder will "suck" the spent gas out of another, and so on (in conjunction with the piston pushing it out). When you go too big of an exhaust, you can lose scavenging and it can result in a loss of power. You basically want to match your exhaust size to your power level. |
#32 |
ohh ok but i am still confused i have a carb 351 do i want straight pips or dumps when it comes to wanting more power?
![]() because i was told straight pipes give the back pressure not dumps so i am confused here |
#33 |
1988 Mustang 5.0
Dude get dumps. I drive my car 300+ miles a week on the highway with 4.10's and dumped Mac flowpaths. You get used to it. I think I might get some tailpipes just to make the car look a little better though. I think Lx's look horrible without tailpipes.
#34 |
i mean for power though i dont care at all for the sound as to if it is to loud or not ( my motor can never be TO loud for my ears )
#35 |
1998 Cobra
13.24@105.66
blah blah blah.. backpressure is a myth as far as im concered..
look at any dyno with header and/or exhaust size comparisons.. the bigger exhaust will ALWAYS make more peak power.. now here comes the question.. WHERE do you want your torque band? a stock exhaust will allow for a sooner power curve in the rpm and net a lower hp.. bigger exhaust will allow for a later power curve and make more tq... in racing, you want as much tq at the highest rpm possible.. Even if someone builds a 'street' motor, he could still benefit from a larger exhaust.. go big, you can always build a motor to grow into it. so to answer the dumps question.. it has nothing to do with power, but merely if you can stand the sound of dumps all the time .. nauseating if you ask me.
#36 |
FWIW, dumps under the car make it louder in the car. Good excuse for an amp and a couple subs.
#37 |
1998 Cobra
13.24@105.66
and tear drops for the carbon monoxide.
#38 |
so basically there is no performance difference between flowmaster dumps and flowmaster straight pipes?
#39 |
1993 5.ohhhh
14.47 at 96 mph
The ojly difference with cutting the tail pipes off is sound. That wont affect back pressure in anyway. It's the cutting off of mufflers that will do so.
302 h/c/i
#40 |
ohh ok i got ya, so basically dumps are louder then straight pipes?
Threads Similar to: dump my exhuast
| The GT took a dump... | zinc02GT | The Clubhouse | 13 | September 16th, 2008 11:31 PM |
| To Dump or Not to Dump??? | 2002stang | Exhaust | 10 | July 28th, 2008 03:19 PM |
| should i dump ? | SilverGT04 | 99-04 | 12 | May 13th, 2008 01:37 AM |
| To dump or not to dump | whitemustang02 | V6 Mustangs | 17 | January 18th, 2008 06:21 PM |
