cast iron vs aluminum heads
Old December 9th, 2006, 05:57 PM   #1
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
besides weight and heat dissapation, is there truely an advantage of using alumin heads as opposed to iron heads.
The motor they are going on is a 351, 14cc dish pistons, fairly big cam 238 or 248 duration @.50 .540ish lift and on top of this it will at least a 150 if not 200 shot of the juice.
The heads offered in aluminum or cast iron same specs, on both heads just different materials,
200cc intake, 66cc exhaust 2.02 intake valve. 1.60 exhaust
with either a 58 or 64 cc combustion chamber
enjoy it guys
Just a truck
Old December 9th, 2006, 06:16 PM   #2
Justincredible's Avatar
Justincredible is on a distinguished road
You can run more compression with an alum head ,on pump gas, due to its better heat dissapation properties.
I also like the fact that with an alum head, your removing a sizable amount of weight off the front of the car.
But just the same.....Ive got some close freinds who are running 5's with thier iron heads.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old December 9th, 2006, 06:21 PM   #3
86er's Avatar
well im lookin for about 9.5 or so max compression, and with those 14cc pistons im think 58cc combustion chambers should put it close on a stock deck 351.
I know the weight of almost 50 lbs off the front is huge, just lookin if theres anything ive overlooked in the aluminum vs cast iron
Just a truck
Old December 10th, 2006, 07:03 PM   #4
81 Merc. Capri is on a distinguished road
Send a message via MSN to 81 Merc. Capri Send a message via Yahoo to 81 Merc. Capri
cast iron
cast iron heads are more durable especially on the 'juice' a blown headgasket can ruin a set of alumies really fast, cast iron just needs new gasket. also alot less expensive than T F or edelbrock, although i heard those gt40p heads off exploders give you about thirty more horses with the intake , cast iron heads.
So many Camaros... So little time....
Old December 10th, 2006, 07:52 PM   #5
IcantDo55 is on a distinguished road
I made 500rwhp with GT-40 irons, good heads. But I'm switching to AFR205's to make 800 rwhp
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old December 11th, 2006, 08:46 PM   #6
86er's Avatar
RHS makes a good head for 405 bare, cast iron 200cc intake, 60 or 66 exhaust, 2.02 intake valve, 1.60 exhaust, 58 or 64 cc combustion chamber
and like I said earlier its offered in aluminum or cast iron. I know if you skimp on heads, you can really fubar your build up.
Just in, victor jr's brand new for 700 bucks, gotta love broke friends,
guess this debate is solved
Just a truck
Threads Similar to: cast iron vs aluminum heads
Ported polished cast gt40s 86gt_wit_Ts 5.0 Mustangs 2 July 16th, 2007 01:07 AM
Iron Mike 03 R Code Videos 5 June 14th, 2007 08:13 PM
5.0 aluminum heads joey308 5.0 Mustangs 1 March 3rd, 2007 05:25 AM
Die Cast turp The Clubhouse 24 September 20th, 2006 12:33 PM
