When the engine is cold, she starts up great. No starting issues. Sounds healthy and everything. After running for a while, when I try to start it, it sounds like the battery has no juice, when it does. It tries to crank over, but has a very hard time. Last night, turned it off for 5 min or so, came out and it would not start worth anything. Where should I begin?
Start at the battery, have it tested. If it tests ok, check all your grounds and power connections, the hotter the connection is, the less it conducts, producing heat ect, ect... It sounds like a starter going bad to me but start with the free stuff first. No sense throwing money at it unless you are sure thats the problem.
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
