LinkBack (1) | Thread Tools |
#1
1990 mustang gt
roll cages
i have a 90 hatchback and i am looking to put a cage in it ...8pt. all the cages i have found so far the back bars only go to the wheel wells. i want mine to go all the way back...will have i have to custom make it or is there a kit out the for what i am looking for? also swing out bars..kinda of a heavy. if some one or somebady can send me a link would like it thanks
1989 Mustang LX
10.98@126.7 NA
Well, if you are looking for a cage / roll bar to do the best job of protecting you and stiffening up your car so it will hook and launch the best, it should land at the rear wheel wells. That's why all of the "kits" are designed that way. When you extend the rear bars out to the rear of a Fox body, you apply forces behind the center point of the spring mounts and flex the uni-structure and unload the suspension. You can bring down tubes off of the rear extended bars and land on the uni-structure near the shock mounts and triangulate the cage but you really should have an experienced cage fabricator do the deed for you.
Never fast enough.
1990 mustang gt
ok thanks...do you recommend any place to purchase
meh
I think he means you should have someone professionally install it... I'm sure it requires some welding, etc. Also just in my own experience with any "kit," nothing fits perfectly, so fabrication is usually necessary.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
#5 | |
Their kits are nice but most likely you are going to have to fab something up for swing out bars. You can buy the parts or the swing out kit but I haven't seen a kit that comes with the swing out kit.
1986 lx notch
9.98 @ 135
+ 1 on the S & W . you can but a swing out kit from them also
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/92932-roll-cages.html
| roll cages | This thread | Refback | October 23rd, 2008 03:47 AM | |
Threads Similar to: roll cages
| roll cage | 1BADSTANG | 5.0 Mustangs | 7 | August 27th, 2008 09:43 PM |
| How to roll my fenders | flattusmaximus78 | 5.0 Mustangs | 36 | August 22nd, 2008 03:23 PM |
| Window won't roll down | Muscletang | 96-98 | 11 | March 16th, 2008 10:07 PM |
| How I roll | 67/07 | The Clubhouse | 260 | September 29th, 2007 06:02 AM |
| Roll cages | scxc15 | V6 Mustangs | 23 | April 11th, 2007 11:17 PM |
