Smog and AC delete.
LinkBack (2) Thread Tools
Old October 14th, 2008, 11:00 AM   2 links from elsewhere to this Post. Click to view. #1
90 Mustang GT Convertible
INSTALLER020 is on a distinguished road
Send a message via AIM to INSTALLER020
Smog and AC delete.
Can I just remove them and get a shorter belt or do i need to get some sort of delete kit with a pulley on it?
Thanks,
Matt
1990 GT Convertible
Soon to have GT40P Heads, GT40 Intake, 65MM TB, 70MM Mass Air, E303 Cam and 3.73's.
Old October 14th, 2008, 11:27 AM   #2
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
some people use a shorter belt. i used a Pro5.0 smog pump eleminator pully
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old October 14th, 2008, 12:50 PM   #3
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
on the smog pump you can use a short belt as long as u dont have underdrive pulleys.....and on the ac the best way to go is the kit that relocates the power steering up close to where the ac was
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old October 14th, 2008, 02:51 PM   #4
So would this be the right way to do what i want?
82-93 OFF ROAD ACCESSORY DRIVE KIT, 5.0L MUSTANG
Or is this unnecessary?
Thanks,
Matt
1990 GT Convertible
Old October 14th, 2008, 02:54 PM   #5
1990 Mustang GT
that would be a good kit.....and at a good price
1990 GT
2004 Impala SS
2001 Tacoma
Old October 14th, 2008, 03:17 PM   #6
Underdrive pulley's....dumb question.
what exactly do they do?
Thanks,
Matt
1990 GT Convertible
Old October 14th, 2008, 03:51 PM   #7
1990 Mustang GT
which part of the kit are you tlkin about.....that kit looks like it deletes smog pump...adds underdrive pullies and deletes ac
1990 GT
2004 Impala SS
2001 Tacoma
Old October 15th, 2008, 12:21 AM   #8
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
Thanks,
Matt
Underdrive pulleys reduce the parasitic loss on the motor which in turn frees up a bit of power.
Old April 28th, 2009, 04:29 PM   #9
87 CAVALLO is on a distinguished road
What Size Belt Do I Need If Im Pulling Out The Ac Without Adding A Delete Kit?
Old April 28th, 2009, 07:19 PM   #10
5.0 street stanger is on a distinguished road
When i deleted my AC comp and air pump I used a shorter belt and made a bracket to relocate the belt tensioner. I didnt want to have to get the delete kits cause the whole point to removing them was to not have to drive any more pullies or accessories. I moved the tensioner to right about the water pump with a bracket i made and used my old belt to mach up what size belt i needed. i cut the belt and ran it with the new set up and tape the belt back together once it was cut to size and took it to advanced and told them i needed a belt that length. works great and i dont have any idler pullies to drive. I just drive the water pump, alt, and power steering now. Next im planning on getting some underdrives and getting 12v motors to drive the alt and powersteering, along with an electric water pump, and electric fan. then I will have no accessories to drive, freeing up all the power that was lost to the accessories.
Old April 28th, 2009, 08:22 PM   #11
stfudvs's Avatar
302 5.0
stfudvs is on a distinguished road
i wish i didnt have to smog my car i want to delete my smog pump
if you were on a bicycle and we were going up hill i could beat you in a race
Old May 4th, 2009, 01:42 AM   #12
u could always drive it with an electric motor so you dont have to run it off the motor. Summit sells electric motors for water pumps that have a motor, bracket and a small belt that hooks up to the pump but i dont see why u couldnt use that kit and hook it up to the pump.
Old May 4th, 2009, 02:01 AM   #13
ViperblueGT's Avatar
1988 mustang GT
13.06@106.09
ViperblueGT is on a distinguished road
the best way to do it would be to pull the ps up by where the ac was...the smog can be taken out for just a shorter belt..... in my opinion putting a delete pulley on instead of the object that was there is a waste of time.... shorter belt means more horses.... it''s been proven that a motor with no belt puts twenty more horses to the wheels ...but you cant really do that so everyone usually just strives to use the shortest belt possible....
88 mustang 5.0 e7 heads edelbrock intake mezeire electric water pump... electric fan... f cam 4.10 gears t-5 tranny best pass 13.06 @ 106.09
Old May 4th, 2009, 04:05 AM   #14
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
How do you mean? I'm running underdrive pulleys, and no smog pump. I have an 82 1/2" belt. (with A/C)
Agreed...
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old May 4th, 2009, 09:32 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Thanks,
Matt
You can remove the smog pump but you need either an idler pulley or move the power steering pump up (like on non a/c mustangs) when you remove the a/c. Just running a shorter belt won't work because it will make contact in the middle in the water pump area. FYI, a/c doesn't rob any horsepower when its off or at wide open throttle so don't use that as a reason to remove it. If it works, I'd keep it.
Old May 4th, 2009, 11:58 AM   #16
You can just reuse your stock tensioner... like what mustank did
i've used this setup on an 87 with smog and ac deleted without moving the ps up and it's been running without a problem for the last year.
Old May 4th, 2009, 12:06 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Only if you get rid of your power steering. I've been running that belt set up like for years but I'm not a pussy so I don't need power steering.
Old May 4th, 2009, 01:34 PM   #18
91 LX
13.7@101
i have underdrive pullies and a short belt
Old May 4th, 2009, 03:14 PM   #19
hahah my turbo car was converted to manual steering two years before I stopped using it for dd duty so im not a pussy neither but in this case I've used the above method but longer belt on a friends 87 coupe that still had power steering. We just left it in the stock location and it's fine.
Old May 4th, 2009, 03:28 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The belt must slip like a mother ran like that. Still running the power steering there will be hardly any belt contact on the crank pulley. As soon as you load it by turning the wheels it has to be slipping. Certainly not an ideal set up but if its working, good for you guys.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/93019-smog-ac-delete.html
mustang build questions This thread Refback August 23rd, 2010 03:28 PM
Smog and AC delete. This thread Refback November 7th, 2008 01:03 AM
Threads Similar to: Smog and AC delete.
Smog Pump Delete? 5-0stank 5.0 Mustangs 20 July 14th, 2008 04:24 PM
Smog delete Timm10221 5.0 Mustangs 0 April 22nd, 2008 08:06 AM
smog and ac delete... e3sean 5.0 Mustangs 7 March 1st, 2008 01:31 PM
AC Delete and Smog Pump Delete triplethreatt77 5.0 Mustangs 14 December 24th, 2007 06:09 AM
Smog Delete? 95blackbeauty 94-95 8 December 20th, 2007 02:44 AM
