Discussing t-5 to c-6 swap questions in the 5.0 Mustangs Forum. ive been searching on the site and searching on google and many other sites and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1983 GT
UNKNOWN
1983 FOX BODY-LIL SOMTHIN IN PROGRESS |
go to a c4, c6 is way over kill
86 F-150 302 daily driver 86 gt - tops 351, jugged and c4'd 1.57 60ft 6.57 1/8th 107mph waiting to up the pills http://www.moddedmustangs.com/forums...kesyou_750.gif |
1990 Mustang LX
9.36@143 mph
A C4 is what you want, not a C6. Your crossmember, trans mount and driveshaft will work. You will need a flexplate from a Mustang with an AOD to maintain the 50oz imbalance of the 5.0 liter H.O. engine if that is the engine you have. You will also need a good torque converter. C4s have two different bellhousing sizes. I believe the AOD has the same size flexplate as the larger C4 bellhousing. I'm 99% positive of that. You will have to wire up a neutral safety switch on the shifter but that is not a big deal at all. Make sure you get a good transmission cooler too.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
1983 GT
UNKNOWN
the only 2 different bellhousing sizes would be a big block or small block so if i get a flexplate off any 5.0 it should work with the small block bellhousing i know that much but that for letting me know i can use my crossmember and driveshaft and mount......thats gonna save alot of money on my budget.....thanks for the input
#5 | |
1990 Mustang LX
9.36@143 mph
1990 foxbody
14.8@98mph
so what do you plan on doing with your t-5?
i really need to get a t-5 fairly cheap...what doya think huh.huh.
your always faster then the guy in the mirror |
Threads Similar to: t-5 to c-6 swap questions
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
| Motor Swap Questions 5.4L 331 | Smoph | 5.0 Mustangs | 2 | June 4th, 2007 01:07 PM |
| pi swap questions | LaserRed96GT | Modular Mustangs | 0 | January 10th, 2007 11:51 PM |
| Questions On A 2.3 To 5.0 Swap! | tatterd87 | 2.3 Mustangs | 1 | September 25th, 2006 02:34 PM |
| Questions On A 2.3 To 5.0 Swap | tatterd87 | 5.0 Mustangs | 3 | September 22nd, 2006 03:48 AM |
