blown head or intake gasket
Old October 14th, 2008, 09:08 PM   #1
1993 notch
joe 5.0 is on a distinguished road
ok i know its one or the other but would like to know what you think i realy dont want to dig in again
just finished building this car
car running fine no smoke out exhaust avg about 200 degrees in trafic and 180 on he highway plugs look good
but coolant in oil noticed oil was milky when i went to change it and coolant came out coolant level low but no visable leeks
car is blown and pulls over 500 hp at rear
drove it home from dyno and car ran great put it away for a couple of weeks decided to change oil when i found the above.
Old October 14th, 2008, 09:11 PM   #2
1987 ford mustang gt
well see when shes done
head gasket or a crack internally.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 14th, 2008, 10:24 PM   #3
ryans88gt's Avatar
Head gasket. try felpro 9333pt1 gaskets. They are boost friendly and seal the coolant passages really well. It is possible that the intake gaskets are leaking coolant into the lifter valley, but if that is the case, most likely it is because boost is pressurizing the coolant via a blown head gasket. Either way I would at least take the heads off and inspect.
Threads Similar to: blown head or intake gasket
Blown Head Gasket saltydog_NM 5.0 Mustangs 8 August 28th, 2008 04:01 PM
=( blown head gasket itschristorres8 V6 Mustangs 17 October 23rd, 2007 11:14 AM
blown head gasket 5.0pwr 96-98 2 September 17th, 2007 11:57 PM
blown head gasket.......new heads? sniperrider 5.0 Mustangs 18 April 25th, 2007 11:10 PM
Blown Head Gasket Lax89 5.0 Mustangs 10 February 17th, 2007 08:01 AM
