150 shot?????
Old October 16th, 2008, 06:24 PM   #1
1988 gt 5.0
1988gt 5.0 gt40p heads,cobra intake, f303 cam
worlz08 is on a distinguished road
150 shot?????
can i spray 150 or 100 shot on a SD 88gt f303 cam gt40p heads cobra intake and hyper pistons?????
Old October 16th, 2008, 06:29 PM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i dont know if the speed density will make a difference but otherwise you could on a maf car......you can spray 150 on a stock fox
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old October 16th, 2008, 06:41 PM   #3
1988 gt 5.0
thanks
Old October 16th, 2008, 06:46 PM   #4
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
You can do 150 on hyper pistons but it's sketchy. Sd if fine it makes no difference on a wet kit. If your for sure you have hyper pistons I'd stick to 100 shot and start working on suspension or something.
Old October 16th, 2008, 09:23 PM   #5
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
why does your 88 have hypereutectic pistion?
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old October 17th, 2008, 09:23 AM   #6
Hunt_chevs's Avatar
88 Gt
Not Slow
+1
Old October 17th, 2008, 09:29 AM   #7
1996,mustang
around 5's 0-60
white_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these parts
you can i seen it done, he gots his internals build for it
bbk cai
8.8 373
dual exuast
ported heads
bored 30 over
forge crank
aggressive cam
minor shit also
[SIZE="4"][COLOR="Red"]crew member #1 that loves mods and administrators[/COLOR][/SIZE]
Old October 17th, 2008, 09:29 AM   #8
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
http://www.moddedmustangs.com/forums...ml#post1514688
Old October 17th, 2008, 10:23 AM   #9
Hunt_chevs's Avatar
88 Gt
Not Slow
Old October 17th, 2008, 10:34 AM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Pick up an NOS part# 05115-II nitrous kit and go to town. Read the directions completely (twice if you need to) and make sure the kit is installed properly. Make sure you have full knowledge of what nitrous does and how to operate it. Also make sure you have all of the safety devices like blow down tube and blow off cap.
Unless you swapped a 93-95 engine in your car, you have forged pistons.
Old October 17th, 2008, 10:35 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can what? Split the block? I run 15lbs of boost on a stock block and it hasn't split yet. 15lbs of boost makes a bit more power than 150hp of nitrous
Old October 17th, 2008, 08:55 PM   #12
1988 gt 5.0
i put new pistons on the car thats why there in there
Old October 17th, 2008, 09:42 PM   #13
Hunt_chevs's Avatar
88 Gt
Not Slow
stock internals too?
Old October 17th, 2008, 11:20 PM   #14
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
why would you put hyper pistons in?
Old October 17th, 2008, 11:42 PM   #15
1988 gt 5.0
they came with the kit from summit
Old October 18th, 2008, 10:10 AM   #16
1998 Cobra
13.24@105.66
you took out forged pistons for hypereutetic?
weeee foooord!
Old October 18th, 2008, 11:09 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No, not in this car but if I would have built the engine I would have did alot different.......like leave the stock crank, rods and pistons in it. I know many people that have made 500+ at the tire with stock internals. A good friend of mine made 555hp at the tire and raced the car religiously every weekend for 2 years. The engine is still alive too.
Old October 18th, 2008, 11:15 PM   #18
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
<-- my boy ran high 10s in his 85 mustang with a cougar motor ( stock bottom end complete with cast pistons ) a cam , ported stock heads, rpm intake, and 750 carb and a 200 shot for the longest time. it was his daily driver and he went thru a bottle of nitrous almost every week.
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Threads Similar to: 150 shot?????
150 shot mystang0673 99-04 12 September 10th, 2008 06:18 PM
150 shot? drazga97 99-04 50 August 2nd, 2008 05:46 AM
new best record w/ 150 shot 06TYRFRYR 2005 - 2010 27 May 7th, 2008 02:11 AM
nx 150 shot on 95 gt? show95stang 5.0 Mustangs 1 February 3rd, 2008 03:02 PM
