LinkBack (1) | Thread Tools |
#1
Building a 306 few questions
ok i have come to a decision for what i am building and got a few questions..
here is what i have as far as the motor at the time: tfs upper and lower edlbrk 70mm tb 255lph pump 30lb injectors fuel rails and regulator pulleys custom cam bbk headers w/catless h pipe, flowmasters cai crane rr's and ignition box and maybe i forgeting things i am wanting to run a supercharger as much boost as safe. questions: can i use stock crank and rods or just crank. what pistons are good with what i am doing? what heads are good (cc) and should i get block bored 4.030 or like 4.0307 to allow lots of boost?
90 lx hatch |
The stock crank, rods and pistons will live longer than the stock block will. I wouldn't worry about boring it. You are wasting your money there unless the cylinders are damaged. Boring an engine will give you zero horsepower. Have it tuned by a reputable shop and keep the rpm down. 500-550 rwhp is about the safe max.
The Razor's Edge
dude he is from Fond du Lac, Wisconsin are you really going to trust him...lol
1987 ford mustang gt
well see when shes done
shutup skittle
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
I guess I'm not understanding what you mean by that or what relavance where I live has to do with the information...
cyl heads??
weeee foooord!
well i had the block magnafluxed by a shop and i have it back now can i start putting it back together? and i have a few pistons with bad pins....so replace pins bearings and rings and i should be good to go?
90 lx hatch |
or can i even buy new pins?
90 lx hatch |
while it's apart put new forged pistons in there please...
weeee foooord!
k not a problem kieth black pistons will do right? as long as i make sure to get 4.000 pistons...lol the block is torn apart right now so im just kinda cleaning things while i figure things out
90 lx hatch |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/93382-building-306-few-questions.html
| Building a 306 few questions | This thread | Refback | October 17th, 2008 06:51 PM | |
Threads Similar to: Building a 306 few questions
| Building rear end few questions?? | BREEZY B | 99-04 | 2 | May 29th, 2008 07:06 PM |
| Building a 306 | Futurebuilt306 | 5.0 Mustangs | 28 | May 1st, 2008 04:57 PM |
| Building My 306! | JONJON | 5.0 Mustangs | 19 | December 7th, 2007 03:56 PM |
| Building a 306??? | JONJON | 5.0 Mustangs | 57 | October 22nd, 2007 08:47 PM |
| Building a 347 Soon..Questions...So Starting Early | Speedstang302 | 5.0 Mustangs | 10 | September 25th, 2007 09:53 AM |
