NOS question
I am thinking about buying a NOS setup and i was wondering how it works exactly... You press the button and it applies the full tank or does it do like short bursts? or does it do it work for how long u hold the button?
also i was wondering how where you refill the tank and around how much that cost roughly. I know nothing about NOS. so i have no idea between wet and dry etc. |
2002 Gt
Not Slow
![]() iTrader: 1 reviews
it costs anywhere from 3-5 dollars per lb. to fill depending on the area,. most systems run off of a wide open throttle switch which means electronically the nitrous is activated when the throttle is wide open. The term "wet" refers to the kit adding fuel along with nitrous, as oposed to "dry" which doesnt
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
2008 Jeep Rubicon
a brick can go faster
I'm no expert at NO2, but from what I've read.
As long as you hold the button down, it's spraying (unless you do it right, then it will only let you spray at a certain RPM, then stop when you get to high). Prices, no idea. refills, no idea, maybe a welding shop or a track with a shop? wet injects directly into the cylinder (corrected above^) (i think) and dry just sprays into your intake (again, I think). |
Do yourself a favor and pick up a book on nitrous oxide such as SA Design SA50 - SA Design How to Install and Use Nitrous Oxide Injection for Maximum Horsepower - summitracing.com or Motorbooks International 780760308370 - Motorbooks International Automotive Reference Books - summitracing.com
#5 | |
2002 Gt
Not Slow
"Wet systems" mix the fuel and nitrous together. "Dry systems" use the fuel injectors for fuel enrichment and spray the nitrous separate. Joey has a carbureted engine so his only option is a wet kit.
Get a WOT switch
PeteAndersonRacing.com |
and a window swcith so you dong spray to low and puddle or dont spray to high and blow your shit to hell and back
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
ok thx guys thx for the book links Darrell. how many lb is it per tank around?
also Darrell some small updates on the car they pulled the distributor and it had a bronze gear. she should be going on the dyno any day but this guy has been so busy ill be sure to let you know. |
whatever you want...you can get any size pretty much
typcialy people run 10lbs
ah ok so its pretty cheap to fill the tanks up, around 50-100 dollars?
i pay 45 bucks to get my 10lb filled
depends where you go tho. if i went on a 45min drive itd olny be 30 bucks but id lose so much in gas it wouldnt be worth it
oh true hmm that's great so nos used properly is a great cheap mod.
your looking at a grand to include all the saftey features and tune....
and nos is a brand. say n20, nitrous, or spray
2002 Gt
Not Slow
yes, you technically dont even need all the "safety" stuff demello posted,.. but it certainly wouldnt hurt
yea joey. all you technically need is a bottle with a brainded line to your engine bay with a nitrous soleniod and jet and an activation swicth (dry shot)
but id suggust investing in all the other things in my sig....
95 Mustang GT
I call all of them NOS whether its nos or zex or whatever.....just like I have always called all sodas cokes I hate the word soda...and where we grew up we said hey you want a coke....yeah sure grab me a dr. pepper...
![]() People should think about boarding up their glass house before starting a rock fight! |
2002 Gt
Not Slow
how do you like that juice mello?
not using it rite now...wiating on a chance to datalog and send joe some info for my cusomt tune
![]() i just got the tach adapter and my shift light in last nite....
Threads Similar to: NOS question
| NOS Question | flamed 98 gt | 5.0 Mustangs | 8 | May 25th, 2008 07:24 PM |
| Nos Question | Timmano | V6 Mustangs | 18 | March 16th, 2008 02:27 PM |
| nos question | tom2000r | 99-04 | 2 | February 10th, 2008 04:23 AM |
| Question On Timing With NOS | Newtgadget | 5.0 Mustangs | 37 | December 17th, 2007 06:32 PM |
| NOS Question | fsttang96 | 96-98 | 9 | October 31st, 2007 04:59 PM |
