engine issues
Old October 18th, 2008, 03:37 PM   #1
1985 Mustang GT
viperlocc is on a distinguished road
engine issues
Helping a friend out with his '85 5.0
here is what happened: pulled away from a stoplight, switched to second gear, hammered on the gas and it popped out of second and went redline (not sure how far), put it back into second and took off fine. after he slowed down, driving normal 30mph in 3rd, the idle started to act irratic. car felt as if it wasnt getting fuel. idle was fine, just when driving. no difference can be heard from the engine compartment from what he said.
gonna do a compression test today for starters and check the plugs. he did say when he started it back up, it was smoking gray smoke, not alot, but he did mention it sat for 2 weeks. motor has almost 200k on it. windsor jr heads, e303 cam.
Old October 19th, 2008, 10:20 AM   #2
1985 Mustang GT
UPDATE/bump
checked the plugs, most of them were pretty dark with buildup on them. Figure the car sat for 9 to 10 months. The only ones that worred me are the 1st one and the 8th one. (1st one is drivers side front, 8th one is passenger side back). Those ones were a little white, no build up, and the 8th one, the electrode was wore down a bit.
The other thing i noticed was the passenger side valve cover, where the breather is, the rubber piece that stops the oil from splashing into the breather was tore. it never was before.
cant start it, hopefully new plugs will get the car started. what timing should be ran with windsor jr heads/e303 cam? someone set it at 16 before, brought it down to 12.
Old October 19th, 2008, 02:24 PM   #3
1985 Mustang GT
update
new plugs installed, got it started. engine sounded the same as before, little bit of smoke out of the passenger exhaust and a weird smell. After it got to 180* temp, the idle acted irratic, and the engine shook between 1200rpm's and 2500rpm's.
any idea's?
Old October 19th, 2008, 08:25 PM   #4
1989 LX coupe 5.0L
89lx is on a distinguished road
did you do a compression check well you had the plugs out?
Old October 20th, 2008, 11:24 PM   #5
laztug's Avatar
1993 Mustang GT
laztug is on a distinguished road
Wish i could help you out dude.......BuMp!
Old October 20th, 2008, 11:40 PM   #6
e3sean's Avatar
1988 lx
9.68@142
how long was it redlineing for? how is the oil pressure? could be anything
<font size=4><b>MILITARY CREW
Old October 21st, 2008, 06:32 PM   #7
1985 Mustang GT
oil pressure was good, redline for a very short time. decided to tear apart anyways and rebuild so...thanks for the help
Threads Similar to: engine issues
engine issues viperlocc 5.0 Mustangs 4 October 22nd, 2008 11:29 AM
some issues jeffmarble 94-95 12 March 30th, 2008 07:31 PM
Potential problems/issues with engine swap robz301 V6 Mustangs 22 December 26th, 2007 02:19 AM
Issues! Help! (Engine) ericsc 2.3 Mustangs 1 December 7th, 2007 03:36 PM
93 5.0 with issues hrsepwr44 5.0 Mustangs 2 May 8th, 2006 11:36 PM
