electric fan wires overheating bad
I have a 95 gt and my electric fan wires are getting so hot they are melting together. I have the power wire running straight to the battery, and the ground running through a toggle switch inside on the console. I keep burning through toggle switches too. Anybody know what I'm doing wrong? Thanks
2003 Black Cobra. 2.3 whipple JLT RAI Dragon t/b 60s BAP Mafia Xcal3 MAC LTs w/ORX-pipe Borla stingers Billetflow IRS brace Eibach springs 1989 GT AFM b-31 cam crane springs 6.3 pushrods elec. W/P/fan 3:73s Manual steering tri-ax Shorties-orh-flows |
Atomized
you need to have it on a relay man it'll help a bunch.
1985 Mustang GT
When I hooked up things to a toggle switch i would put it on the pos. side, not the neg. side.
run a straight good ground and put the toggle on the pos side and see what that does for ya |
I tried it on the pos side and it heated up just as much. I'll try the relay thing and see if that helps.
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
How old is the fan? Sounds like it is pulling to many amps & no fuse to protect the system.
It's not that old, probably a year. Do I need a fuse and a relay or just a fuse.
89 GT
You need to put a relay in and switch the relay. You also need to put larger gauge wire in and a fuse. The reason you are burning up switches, is because the fan draws too much current for the switch. The reason you are burning up wires is because you are using too small of a wire. You're going to want to find out how many amps the fan draws because that will tell you what size wire and relay to use. If you can find that out, I can point you in the right direction.
#8 | |
2007 MUSTANG GT
1989 Mustang LX
10.98@126.7 NA
Basic automotive electrical 101. Check the load (amp draw) of the accessory, determine if it is low enough to be wired directly through a switch (check switch rating). If not, use the proper relay (check rating). The relay is triggered by a light gauge wire and acts as a heavy duty switch. Always use the proper gauge wire and ALWAYS use a properly sized fuse or breaker. Don't just twist and tape wires together, this will result in a poor connection and cause resistance heating at the joint. Solder the joint or use stake-on connectors. Always secure the wires in a loom or at least wire tied to a non-abrasive attachment point(existing loom). I look at an average of 12 car fires a year that result from someone improperly wiring add ons.
Never fast enough.
your running battery voltage into your cabin? not smart.
run a relay and up the guage of the wire. too much resistance in the line.. shit will catch on fire.
weeee foooord!
#11 | |
do you put the relay on the pos side or the neg. ? and which should I run through the toggle switch?
Threads Similar to: electric fan wires overheating bad
| Electric Fan? | JONJON | 5.0 Mustangs | 7 | December 1st, 2007 02:05 PM |
| electric fan | hmotes | 5.0 Mustangs | 5 | January 14th, 2007 07:23 PM |
| electric fan vs fan clutch | hmotes | 5.0 Mustangs | 8 | December 19th, 2006 02:03 AM |
| Flex-Fan (Non-Electric) Bad For Gas Mileage | cobraetti | 5.0 Mustangs | 9 | November 26th, 2006 05:41 AM |
| Electric fan or Flex fan? | vivoronte | 5.0 Mustangs | 20 | February 10th, 2006 10:58 PM |
