LinkBack (1) | Thread Tools |
#21 |
#22 |
So far so good....figure about 650 flywheel hp
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#23 |
ok so heres a question (not to hi-jack the thread)
on my 78, i have a 306 with a stock crank, but its got a set of hypertectic flat tops, it puts the compression around 8.5:1 i would like to get some big chamber heads on it to get it around maybe just 8:1, then do a big single, what do you think it could take? (the engine only has 2k miles Last edited by 78mach1; October 21st, 2008 at 02:48 AM. |
#24 |
don't worry you shouldnt have any problems just make sure you get the car tuned with a chip on a dyno after you install the supercharger i recommend getting a 4 bank SCT chip, order it blank, and have someone tune your car so it is safe
#25 |
I was refering to my daily driver. 100% street car that has only seen the track a couple times. The white 93 GT that I have for sale. 15psi, stock block and pump gas.
#26 | |
#27 | |
or do you feel that going threw all the trouble of doing a turbo set up, i might as well have a bottom end that can support what a turbo is capable of? |
#28 |
You don't need 8.5:1 (or 8:1) for 8psi. 8psi is low boost. Your engine will hold that just fine. In your last post you said "big single". When I think of a big single, I think of a 88mm or bigger turbo pumping out a ton of boost. Your engine will not handle that but it will handle 8psi safely. I would run 9:1 though. You don't need such a low compression ratio unless you are running alot of boost.
#29 |
1989 Mustang Gt
Run me and find out!!!
Its an inside joke about a member that is now banned.
#30 | |
do you think that building a turbo set up to run 8-10psi is a waste of time? with what i have, what do you think my weakest link is? crank? pistons? |
#31 |
Pistons are going to be the weak link in your engine. 8-10psi is going to be about the max with those pistons.
#32 |
You can run a lot of boost on hypers, 20+ PSI. As long as you have 0 detonation. The slightest hint of detonation and you will have piston pieces instead of whole pistons.
With 8-10 PSI, it'd be a lot easier to just go supercharged. You give up a little power, but for a street car, 600 hp is overkill anyway.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/93631-would-i-crack-my-block-if-i-did.html
| Would i crack my block if i did this? | This thread | Refback | November 5th, 2008 07:02 PM | |
Threads Similar to: Would i crack my block if i did this?
| The New COD Crack... | ChrisJ | The Clubhouse | 4 | June 22nd, 2008 04:09 PM |
| I crack myself up.... | e3sean | The Clubhouse | 57 | April 4th, 2008 08:36 PM |
| Crack Is Bad | 90mustang50 | 5.0 Mustangs | 4 | December 9th, 2007 12:52 AM |
| Re: On Crack Much? | MSO | The Clubhouse | 9 | October 7th, 2007 12:48 PM |
| On crack much? | TheUNZippee! | The Clubhouse | 16 | October 7th, 2007 09:35 AM |
