Discussing Learning how to search/Before you post in the 5.0 Mustangs Forum. Searching for hard to find information is a time-consuming, but not difficult, task to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Searching for hard to find information is a time-consuming, but not difficult, task to accomplish.
You may say to me, "but I looked and I couldn't find anything!" It's not so much that there isn't available information on your subject, it's more like you don't know how to search for it. There are search engines designed to give you the information you desire, the most common and the one being used in this article is Google. However, most forums (such as this one) have a search function that will allow you to peruse the site's threads and posts. Of course, searching requires a moderate amount of reading and searching, and some people are obviously better at it than others. However, that doesn't mean you should leave it to them entirely, because just like everything else in life, you get better at searching for info the more you try it. And most of the time, the answers you'd get would be achieved from searching anyways. I'm going to give you the basics and some tips in this article that will help you on your quest to learn to search for your own information. Some basics about questions;
Since this is a car forum, I'm going to give common car-related questions. However, these tips can be applied to searching for ANYTHING. With that in mind, I'm going to cover the most common types of questions asked. The first thing I want to cover is comparisons, since most questions are regarding comparisons. The usual post looks something like: "Which is better? A manual or automatic transmission?" Now obviously this has been asked many, many times. However, for the sake of learning how to search, this is a very good way to begin learning. First you would get your "vs" sign, because this is the usual way to compare two things that are usually conflicting, such as auto and manual transmissions. Get your search engine, Google for instance, and type into the search bar: "auto vs manual transmission." This is the very first thing that pops up on the search page for Google, Automatic VS Manual Transmission It gives you all the points and basics of an automatic vs a manual transmission. Now, lets say that didn't quite answer your question. Maybe you want to know what the difference is in terms of performance. So, going right back into your search bar and type "performance auto vs manual transmission." This is the very first thing that pops up on the search page for Google, How to Choose Between a Car With Automatic or Manual Transmission - wikiHow As you can see, it gives you a lot of information you'd otherwise be curious about. Now, the second type of question is usually about technicalities or specifications. These are generally harder to answer because of their nature, most people don't really care about the specifications enough to memorize or have them off-hand. However, for these types of questions, you would usually look up manuals or other explanatory documents, such as guides or how-tos. For example, what are the gears in a T5 transmission? You would open your search engine and type in the search bar: "T5 Transmission Gears." This is the first thing that comes up in the search Ford Mustang: Mustang Tech: Transmission and Drivetrain: Borg Warner T5 Transmission data . It gives you a chart and an explanation, everything you need! Easy so far, huh? Last type of common question is the advisory question. These are more for people who want to know about the experience of doing something, or advice, rather than technical facts. These types are often the ones that end up being posted on the site. These usually entail "What should I expect on my first trip to the drag strip?" So you may think, OK MSO, these are legit questions, right? For the most part, yes. If you're asking for advice, you can technically find someone else in a similar situation and see what people have told him. Then just take the advice given to him and apply it to your situation. You can also directly ask the question if you want, chances are you'll get someone asking what you're asking and you'll be able to read the responses they got. "What's the difference between auto and manual transmissions?" That is most likely going to link you to a help site or a forum and you'll be able to learn everything you need. Well, that's pretty much it. Any other type of question you have, you can use the methods above, or a hybrid of the methods above to get what you want. Searching isn't fun, and reading sucks. But searching on your own will actually leave you more knowledgeable about the subject and will most definitely allow you to help other people when they ask the same questions you had. Mods make wit teh stickeh Feel free to rep meh
bump for sticky?
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
Stuck!
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
1993 Mustang
we'll find out when i come home from iraq.
can i make it sticky
MODS IN GARAGE!FAIL OF THE WEEK!!! http://www.moddedmustangs.com/forums...hat-i-did.html |
On Probation
1998 Mustang gt
Umm this was kinda wired?
Kinda wired ftw!
I agree with you as you said that there is a small amount that your question never been ask since there is a billion people look up for this the same question and already been ask. The key for this is to research your question here before posting a question.
---------- We Specialize in Aftermarket Brake and Power Steering Parts for 65 66 67 68 69 70 71 72 73 Ford Mustangs. Check out our huge online selection. From Mild to Wild we offer it all! Mustang Brake Parts Mustang Power Steering Kits BIG Thanks |
thanks for that tidbit of info bout this forum, good stuff to know, i hate google.
2005 GT Mustang
thanks for the heads up.
Hey it is a nice post and good information posted.
Threads Similar to: Learning how to search/Before you post
| Learning how to search/Before you ask | MSO | The Clubhouse | 8 | October 21st, 2008 12:56 AM |
| learning guitar | silvergtstang99 | The Clubhouse | 11 | April 7th, 2008 01:17 AM |
| Learning About Engines | wadepetersen | All Other Vehicles | 19 | December 20th, 2007 06:40 PM |
| Learning the hard way | GT 849 | The Clubhouse | 11 | January 22nd, 2007 07:35 AM |
